11-27-2019, 04:12 PM
(11-27-2019, 03:04 AM)Bicko Wrote:How it went?(11-26-2019, 09:07 AM)bolinches Wrote: After some back and forth on the ticket, I got a nice video https://vimeo.com/97180298
While I was doing that I noticed that the two little pins on the bottom were loose in my laptop .... I little it of bit of carefully bending and .... fixed.
EDIT: Added picture
You beauty! Thanks so much for the info. I have some free time later this evening, I'll give it a go and report back.
Thanks again.
(11-26-2019, 02:14 PM)pontux_se Wrote: My tab key has come off two times. Not the plastic hinge, only the key.
Not sure if I press it on the edges but I'll pay more attention from now on and try to press it centrally.
I've managed to press the key gently back on both times.
That's interesting, makes me wonder what mine is doing but I hope to not find out.
It's a bit of a shame to have to remember how to 'type around' the issue, especially when your mind needs to be focused on the task you're working on.
I also recently noticed that the Enter key is behaving in a similar way to the tab... almost sticking down on the edge; I wonder if it's a leverage thing, with those keys being somewhat larger than the 'normal' keys. Mine is the ISO keyboard.
