Advice and experience on daily driving ppp
(01-09-2025, 11:17 AM)JadenSki Wrote:
Quote:"chatty cannot process 1 MMSs..."  "mobile data is not configured"
Quote:"Error Sending mms"
I have seen both of those.
As far as I can tell in my testing, Chatty does process the MMS and it shows up in the appropriate conversation. More like a "it is still downloading the MMS and sends a cannot process"
I get this one when my Wifi is ON and connected to my house network. I just turn off the Wifi and the message is sent. I have noticed this for a month or two. I was thinking my updated "pie hole" was blocking the out going messages.
Unfortunately, no matter how long I wait, whether using wifi or not, I never receive the mms even after restarting the phone and/or modem.
(01-09-2025, 12:29 PM)JadenSki Wrote: Unfortunately, no matter how long I wait, whether using wifi or not, I never receive the mms even after restarting the phone and/or modem.
What modem firmware do you have? Stock or Biktorgj?
What ADSP Version do you have on the modem?
ADSP version is the binary files that talk to the towers.
Modem firmware is located in user space on the modem and it talks between the ADSP and Phosh or modem manager.
I have
EG25 Firmware: Biktorgj 0.8.0
ADSP Version: 01.003
I have
I also have
after following your guide.
(01-09-2025, 01:50 PM)JadenSki Wrote: I also have
Have you done a full system update?
sudo pacman -Syu
Did you use the latest image from Danct12?
(I have not tried his latest release, I just keep my phone updated)
https://github.com/dreemurrs-embedded/Pi...h/releases
Chatty does not require mmsd-tng. Do you have it installed? You need mmsd-tng to make MMS work.
sudo pacman -Ss mmsd-tng
sudo pacman -Syu
I have done a full system update.
I did use the latest release.
And I do have mmsd-tng installed.
I don't understand what the issue is. Maybe it does have something to do with using T-mobile through Tracfone? I don't see how it would though.
(01-09-2025, 02:23 PM)JadenSki Wrote: I don't understand what the issue is. Maybe it does have something to do with using T-mobile through Tracfone? I don't see how it would though.
Tracfone is Verizon[1], so maybe try different APN settings[2]...
[1] https://www.tracfone.com/home
[2] https://wiki.pine64.org/wiki/PinePhone_A...fone_(USA)
I am having good results running Mobian sid weekly.  Yes if you use the phone carry a battery, but if you can keep it on standby(set it to go to standby 1 minute on battery) you can get a full day on standby with a few short calls.  Web apps fill out many missing functions, but I also do not get MMSs I have the correct settings, but I guess it is not a major deal to me.
You will find guides for workarounds under my account name for openVPN, fixing the PPp modem issue, reading QR codes, and other little hacks.
As for power there are ways to do it, exploiting the audio hardware buffer, partial CPU mini-wakeups etc that have not been implemented.
Thanks for the info! I'll play around with different settings and let you know how it goes.
(01-09-2025, 03:48 PM)JadenSki Wrote: Thanks for the info! I'll play around with different settings and let you know how it goes.
If tracfone is really moving everything to Verizon, you may need to use ADSP 01.002[1].
https://github.com/the-modem-distro/pine...ARRIERS.md
  The Mobian Phosh Experience mburns 1 3,978 11-18-2023, 08:21 AM
Last Post: crocspot
  Best SXMO experience on PPP getpoked 2 4,054 02-15-2022, 04:35 PM
Last Post: TheBlindEarthican
