Help: Pinebook Pro will not enter sleep [Manjaro 20.04]
#48
(12-29-2020, 10:51 PM)wdt Wrote: >What did I do wrong?
Unless you have right kernel, this is really quite common behavior, others than manjaro
uname -r  ,,, almost certainly will be 5.9,x or 5.10.x
Enable AUR ( package repository), install downgrade ( a shell script ), then
linux-pinebookpro  5.8.x  (downgrade linux)
s3 sleep also requires a bsp uboot too, mainline will not work
The over writing of extlinux.conf, without making an .old (as backup) is quite annoying
I have 5.9.13-1-MANJARO-ARM
so I have to downgrade the kernel for S3 to works?
Won't it automatically re-update after when using PACMAN ?
I have "uboot-pinebookpro-bsp" installed from PacMan. Is it OK ?
RE: Help: Pinebook Pro will not enter sleep [Manjaro 20.04] - by Anarethos - 12-30-2020, 12:26 AM
  Debian on Pinebook Pro u974615 7 1,048 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 290 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,616 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,764 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 336 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,158 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,235 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,055 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 415 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,250 11-23-2023, 07:37 AM
