Help: Pinebook Pro will not enter sleep [Manjaro 20.04]
#20
(06-08-2020, 06:23 AM)sleepingsysadmin Wrote: No, not sure what I did wrong. SD and USB both dont work. The green power light just never flicks on. My theory is SPI flash soft locked but then reset/recovery buttons also do nothing.
It likely isn't SPI, unless you tried writing a bootloader to it. SPI is empty OOTB.
Luckily, your PBP probably isn't bricked, but there may be a problem with eMMC or install on it. Have you checked to make sure the eMMC is fully seated on the board? Sometimes, they can get jostled and unseated, causing sporadic issues in booting. You can also try to boot from an SD if you use the internal switch to disable the eMMC. If you can do that, you're certainly not bricked. Once booted through SD you can use the switch to enable the eMMC again, and use a few commands (in the wiki) to rebind the eMMC for writing.
If after restoring or reinstalling to the eMMC, if you'd like to use BSP uboot to get s3 sleep, I'd suggest using pcm720's u-boot with ArgleBargle's script, as outlined in the previously linked wiki section.
RE: Help: Pinebook Pro will not enter sleep [Manjaro 20.04] - by tophneal - 06-08-2020, 08:54 AM
  Debian on Pinebook Pro u974615 7 1,067 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 292 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,625 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,766 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 340 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,164 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,238 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,141 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 417 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,264 11-23-2023, 07:37 AM
