Official Debian images for the Pinebook Pro!
(04-26-2020, 02:11 PM)tortwigginum Wrote: Debian recently added support for the Pinebook Pro and RockPro64, adding to their existing support for the original Pinebook, Rock64, and Pine64 Plus! I haven't gotten the chance to try these yet but these are presumably based on the mainline kernel, given that Debian Unstable is now using Linux 5.5 with all the necessary patches for the RK3399 backported and Mesa 20.0.4.
Images are being built everyday over at https://d-i.debian.org/daily-images/arm6...rd-images/ where the readme has instructions for how to combine the device-specific partition table and u-boot with the device-independent partition.img.gz that contains the installer such that you can make a bootable SD card with them both.
After being booted, the installer "runs completely in the system's RAM and does not need to load anything from the SD card anymore, so you can delete all existing partitions and use the full card for installing Debian. It is recommended to use the 'guided partitioning' option in the installer to create a proper partition layout on the SD card."
Given that these images purely contain the installer, you'll definitely need an internet connection for it to retrieve the rest of the packages and install a full system. I also believe these don't contain any non-free firmware, so you may need to install over ethernet and then add the non-free repo and install any required firmware afterwards. I'm very interested to see what's currently functional and if there's any unexpected snags or hangups, and I'll definitely update this post with what I figure out after receiving my Pinebook Pro and trying to install this image on it! Smile
I wasn't 100% sure from your posting what Debian version is used for these daily images. I loop-back mounted the partition image and found Debian 11 with Kernel 5.5.
RE: Official Debian images for the Pinebook Pro! - by Der Geist der Maschine - 04-26-2020, 05:04 PM
  Debian on Pinebook Pro u974615 7 1,041 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,615 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,157 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,232 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,027 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,248 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,052 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,443 09-07-2023, 09:38 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,285 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,487 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
