Slarm64 on Pinebook [Slackware Arm - 64 bit]
I recently had to run through this entire process again from scratch after installing a new eMMC module in my Pinebook (now at 128GB, yay!).  I ran into a few gotchas that I thought were worth sharing here.
1)  For some reason, ca-certificates does not get installed correctly into the rootfs, even if it is the latest version.  Reinstalling it re-runs the install scripts and fixes whatever is broken about ca-certificates after first boot.  Before this, you cannot connect to https:// sites.  So, one of the first steps after updating the package list would be to:
slackpkg reinstall ca-certificates
I am not sure what else from the rootfs is broken like this, so I just re-install everything before installing any new packages.  This is easiest done in the base image, because there is less to reinstall.  Anything that got installed in the chroot environment of the base rootfs would not have this problem.  The only package I have noticed a problem with is ca-certificates, but there may be others, but they would be restricted to what comes with the base rootfs image.
slackpkg reinstall slarm64
If you have anything you know was installed on top of the base rootfs (you can usually tell by the timestamps), that would not need to be reinstalled.
ls -lt /var/log/packages/
This is just some quirk about how the base image is built.  I will let the author of the build script know about it, he may already in fact.
2)  The LCD brightness script needs a group to be set for it to work.  The details are at the URL listed in the comments:
https://github.com/pfeerick/pine64-scrip...ess-script
Note that the command in Slackware is not addgroup, but groupadd:
groupadd gpio
The rest of the instructions at that link work as written.  And the rest of my instructions above also work as written if you apply these two extra steps.
RE: Slarm64 on Pinebook [Slackware Arm - 64 bit] - by KRT - 04-12-2020, 10:37 AM
  DietPi OS for Pinebook MichaIng 3 5,335 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 878 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 678 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,563 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,212 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,828 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,221 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,798 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,789 12-25-2020, 04:40 PM
Last Post: ford442
Information Manjaro ARM for Pinebook erchache2000 88 113,058 11-29-2020, 04:36 PM
Last Post: Mr.Fermer
