Optimizing Wifi
(03-08-2020, 02:57 PM)belfastraven Wrote:
(03-08-2020, 04:28 AM)tso4ev Wrote: @Arwen all my other devices work perfect with the 5GHz wifi but the PBP don't even see it do I need to install something extra can you trow me a link if I do thanks
Just for clarification:  are you saying that with the Manjaro build you do see the 5Ghz wifi but not with the default build,  but that you are seeing the 2.4GHz wifi?  If so,  I am assuming that you tried the pbp with each build in the same place.  If that is the case,  can you move the device closer to your router and try?   Also,  if you check the WiFi troubleshooting section of the wiki,  you will get several suggestions about fixing the wifi,  one of which is using the firmware from the Manjaro build...
I've already tried all of this, just does not see it on the default debian  Undecided
Optimizing Wifi - by gleachkr - 03-01-2020, 02:27 PM
RE: Optimizing Wifi - by vrabac - 03-02-2020, 02:50 AM
RE: Optimizing Wifi - by gleachkr - 03-02-2020, 12:26 PM
RE: Optimizing Wifi - by belfastraven - 03-02-2020, 03:32 PM
RE: Optimizing Wifi - by manawyrm - 03-03-2020, 04:07 AM
RE: Optimizing Wifi - by Arwen - 03-03-2020, 09:01 AM
RE: Optimizing Wifi - by vrabac - 03-04-2020, 05:19 AM
RE: Optimizing Wifi - by tso4ev - 03-06-2020, 11:25 AM
RE: Optimizing Wifi - by Arwen - 03-07-2020, 01:48 PM
RE: Optimizing Wifi - by tso4ev - 03-08-2020, 04:28 AM
RE: Optimizing Wifi - by Arwen - 03-08-2020, 01:51 PM
RE: Optimizing Wifi - by tso4ev - 03-08-2020, 02:33 PM
RE: Optimizing Wifi - by belfastraven - 03-08-2020, 02:57 PM
RE: Optimizing Wifi - by tso4ev - 03-08-2020, 04:44 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 813 07-13-2023, 01:50 PM
Last Post: PaulQ
  wifi missing some networks filip 0 594 03-11-2023, 03:21 PM
Last Post: filip
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 1,984 10-08-2022, 06:22 PM
  WiFi Signal Strength? B34N 1 1,205 07-22-2022, 01:35 PM
Last Post: poVoq
  wifi hotspot ip address symbol.accounting@gmail.com 1 1,896 11-07-2021, 12:58 AM
Last Post: dukla2000
  Wifi Troubles IDEFK 17 14,882 05-24-2021, 05:03 AM
Last Post: walterbe
  Pinebook pro poor performance on 5Ghz WiFi Iolaum 10 13,387 05-23-2021, 04:35 AM
Last Post: Ralim
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 3,215 02-05-2021, 09:10 AM
Last Post: BlueJayLinux
  Wifi very slow on PBP Manjaro? WeaseleyRon 2 3,051 01-21-2021, 10:21 AM
Last Post: moonwalkers
  is it possible to get wifi monitor mode on the pbp? BananaPekan 0 1,823 01-17-2021, 01:50 PM
Last Post: BananaPekan
