(02-15-2020, 09:12 AM)rleasle Wrote: I've experienced similar lags using ssh. I assumed it was the CPUs running "on-demand". Could that be what's going on here? I've been meaning to try setting the system to performance mode and see if that keeps things running smoothly. Seems unnecessary to keep the machine in a frugal power-saving mode if it's plugged in.
That was something I wondered about too. I tried upping the CPUs to 2 GHz and on my machine at least it didn't solve the issue. I would be curious if it makes a difference on your machine.
wdt
Quote:I just checked with putty,, using ssh protocol. Seemed fine, normal
Perhaps you could try that?
Great idea. I wouldn't have thought to try it. It definitely is faster, but there is still a noticeable lag when the PBP is connected only to wifi. Instead of taking 10-30 seconds to appear, individual keystrokes come onto the screen in 1-3 seconds, so it is 10x faster. If all else fails, this will be a helpful workaround. Out of curiosity I tried connecting the USB/LAN adapter part way into a putty session, and it made the lag go away.
When you use putty connecting to the PBP (with the PBP only connected to the network via wifi), does it keep up with your typing, or does it have a small lag?
