UBPorts Battery Observation
(03-06-2020, 11:35 PM)falsifian Wrote:
(02-23-2020, 08:01 PM)mpnordland Wrote:
(02-10-2020, 11:32 AM)PinePhoneCoder Wrote:
(02-08-2020, 02:41 PM)mpnordland Wrote: I've noticed that the battery will only charge if I turn on the phone while it is plugged in. After the cord is unplugged charging will not work until the phone is restarted with the cord attached.
Did you remove the plastic between de contacts of the battery used for shipping the phone?
If you are referring to the plastic that prevents the battery from powering the phone at all, then yes. If there is additional plastic to remove I am not aware of it.
I'm seeing the same issue. If I plug the phone in while the phone is off, and boot into UBPorts, the battery charges. If I unplug it, then the battery will not charge again until I shut down.
Using Build #238 from https://ci.ubports.com/job/rootfs/job/ro.../artifact/ , downloaded on March 1.
Responding to myself in case others find this useful: this reddit comment may be relevant. I have been charging my Pinephone with a USB C charger, and that comment claims only USB A chargers will work. I cannot find any information to back that up, but it's the most plausible answer I've found. Unfortunately the only type-A charger I possess provides just 1 amp, so the fact that it does not work either probably doesn't say much.
UBPorts Battery Observation - by appdev46 - 02-07-2020, 08:28 AM
RE: UBPorts Battery Observation - by undo - 02-07-2020, 09:38 AM
RE: UBPorts Battery Observation - by tcode - 02-08-2020, 01:12 AM
RE: UBPorts Battery Observation - by mpnordland - 02-08-2020, 02:41 PM
RE: UBPorts Battery Observation - by ksmithaz1 - 02-09-2020, 08:37 PM
RE: UBPorts Battery Observation - by Bhibb - 02-08-2020, 06:27 PM
RE: UBPorts Battery Observation - by aleadom - 02-09-2020, 06:58 AM
RE: UBPorts Battery Observation - by mpnordland - 02-23-2020, 08:01 PM
RE: UBPorts Battery Observation - by falsifian - 03-06-2020, 11:35 PM
RE: UBPorts Battery Observation - by falsifian - 03-07-2020, 10:30 PM
RE: UBPorts Battery Observation - by kugiigi - 03-08-2020, 09:59 AM
RE: UBPorts Battery Observation - by pepo - 02-13-2020, 01:59 PM
RE: UBPorts Battery Observation - by Giiba - 02-23-2020, 10:03 AM
RE: UBPorts Battery Observation - by pjsf - 03-08-2020, 05:45 PM
RE: UBPorts Battery Observation - by dodoeg - 04-01-2020, 10:20 AM
RE: UBPorts Battery Observation - by somken - 04-11-2020, 12:57 PM
RE: UBPorts Battery Observation - by clover - 04-13-2020, 10:35 AM
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 4,996 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
  online accounts in UBports Uturn 2 4,236 03-30-2021, 09:12 AM
Last Post: Uturn
  UBPorts Not Working Pinoideae 7 9,748 03-13-2021, 01:51 PM
Last Post: KNERD
  How to enable Ethernet with UBPorts and convergence dock? piney-tim 1 3,065 11-27-2020, 07:40 PM
Last Post: piney-tim
  UBPorts Convergence MonCon 0 2,364 11-24-2020, 04:25 PM
Last Post: MonCon
  Looks like I found a mild reason why UBPorts for pinephone hasn't seen much progress. plainenough 13 17,715 11-21-2020, 06:30 PM
Last Post: Nooblife
  "No network" on new UBPorts community edition pinephone professorsnapper 6 7,972 10-19-2020, 10:27 PM
Last Post: htc_tattoo
  UBPorts doesn't boot even after booting into recovery defekto 2 4,540 09-30-2020, 12:16 PM
Last Post: defekto
  Dekko on UBPorts PinePhone usable? djvinniev77 13 15,551 09-17-2020, 03:45 PM
Last Post: yurievitch
  How to enable SSH on UBPorts Ubuntu Touch? eaglecup 12 20,235 09-15-2020, 03:42 PM
Last Post: voidmain
