UBPorts Battery Observation
(02-23-2020, 08:01 PM)mpnordland Wrote:
(02-10-2020, 11:32 AM)PinePhoneCoder Wrote:
(02-08-2020, 02:41 PM)mpnordland Wrote: I've noticed that the battery will only charge if I turn on the phone while it is plugged in. After the cord is unplugged charging will not work until the phone is restarted with the cord attached.
Did you remove the plastic between de contacts of the battery used for shipping the phone?
If you are referring to the plastic that prevents the battery from powering the phone at all, then yes. If there is additional plastic to remove I am not aware of it.
I'm seeing the same issue. If I plug the phone in while the phone is off, and boot into UBPorts, the battery charges. If I unplug it, then the battery will not charge again until I shut down.
Using Build #238 from https://ci.ubports.com/job/rootfs/job/ro.../artifact/ , downloaded on March 1.
UBPorts Battery Observation - by appdev46 - 02-07-2020, 08:28 AM
RE: UBPorts Battery Observation - by undo - 02-07-2020, 09:38 AM
RE: UBPorts Battery Observation - by tcode - 02-08-2020, 01:12 AM
RE: UBPorts Battery Observation - by mpnordland - 02-08-2020, 02:41 PM
RE: UBPorts Battery Observation - by ksmithaz1 - 02-09-2020, 08:37 PM
RE: UBPorts Battery Observation - by Bhibb - 02-08-2020, 06:27 PM
RE: UBPorts Battery Observation - by aleadom - 02-09-2020, 06:58 AM
RE: UBPorts Battery Observation - by mpnordland - 02-23-2020, 08:01 PM
RE: UBPorts Battery Observation - by falsifian - 03-06-2020, 11:35 PM
RE: UBPorts Battery Observation - by falsifian - 03-07-2020, 10:30 PM
RE: UBPorts Battery Observation - by kugiigi - 03-08-2020, 09:59 AM
RE: UBPorts Battery Observation - by pepo - 02-13-2020, 01:59 PM
RE: UBPorts Battery Observation - by Giiba - 02-23-2020, 10:03 AM
RE: UBPorts Battery Observation - by pjsf - 03-08-2020, 05:45 PM
RE: UBPorts Battery Observation - by dodoeg - 04-01-2020, 10:20 AM
RE: UBPorts Battery Observation - by somken - 04-11-2020, 12:57 PM
RE: UBPorts Battery Observation - by clover - 04-13-2020, 10:35 AM
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 4,996 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
  online accounts in UBports Uturn 2 4,232 03-30-2021, 09:12 AM
Last Post: Uturn
  UBPorts Not Working Pinoideae 7 9,738 03-13-2021, 01:51 PM
Last Post: KNERD
  How to enable Ethernet with UBPorts and convergence dock? piney-tim 1 3,061 11-27-2020, 07:40 PM
Last Post: piney-tim
  UBPorts Convergence MonCon 0 2,362 11-24-2020, 04:25 PM
Last Post: MonCon
  Looks like I found a mild reason why UBPorts for pinephone hasn't seen much progress. plainenough 13 17,712 11-21-2020, 06:30 PM
Last Post: Nooblife
  "No network" on new UBPorts community edition pinephone professorsnapper 6 7,968 10-19-2020, 10:27 PM
Last Post: htc_tattoo
  UBPorts doesn't boot even after booting into recovery defekto 2 4,536 09-30-2020, 12:16 PM
Last Post: defekto
  Dekko on UBPorts PinePhone usable? djvinniev77 13 15,549 09-17-2020, 03:45 PM
Last Post: yurievitch
  How to enable SSH on UBPorts Ubuntu Touch? eaglecup 12 20,233 09-15-2020, 03:42 PM
Last Post: voidmain
