Flashing updated uboot in Manjaro
(05-13-2021, 09:00 AM)jiyong Wrote: I stumbled upon this website: https://www.jwillikers.com/update-u-boot...nebook-pro
I followed the instructions.
With lsblk you can check which drive is your eMMC.
With Manjaro it's probably mmcblk2.
sudo dd if=/boot/idbloader.img of=/dev/mmcblk2 seek=64 conv=notrunc,fsync
sudo dd if=/boot/u-boot.itb of=/dev/mmcblk2 seek=16384 conv=notrunc,fsync
Not sure why the second command failed on your PBP.
My heart rate is coming back down to normal. I don't have anything critical on my PBP, but I don't have time to deal with bricking it.
I typed in the commands from the output of sudo pacman -Syu very carefully using mmcblk2.
A new U-Boot version needs to be flashed our install drive. Please use lsblk to determine your drive, before proceeding.
You can do this by running:
# dd if=/boot/idbloader.img of=/dev/mmcblkX seek=64 conv=notrunc
# dd if=/boot/uboot.img of=/dev/mmcblkX seek=16384 conv=notrunc
# dd if=/boot/trust.img of=/dev/mmcblkX seek=24576 conv=notrunc
I did not include conv=notrunc,fsync, just notrunc, as shown.
Rebooted fine.
I took it on faith to use blk2. I'm not sure how to know that with lsblk's output.
NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
mmcblk2      179:0    0  58.2G  0 disk
├─mmcblk2p1  179:1    0 213.6M  0 part /boot
└─mmcblk2p2  179:2    0    58G  0 part /
mmcblk2boot0 179:32  0    4M  1 disk
mmcblk2boot1 179:64  0    4M  1 disk
mmcblk1      179:96  0  3.7G  0 disk
└─mmcblk1p1  179:97  0  3.7G  0 part
zram0        252:0    0  5.7G  0 disk [SWAP]
Flashing updated uboot in Manjaro - by TDC_PBP - 02-07-2020, 08:16 AM
RE: Flashing updated uboot in Manjaro - by jiyong - 05-13-2021, 09:00 AM
RE: Flashing updated uboot in Manjaro - by djhnsn - 05-16-2021, 01:07 PM
RE: Flashing updated uboot in Manjaro - by sciolus - 05-28-2021, 10:44 AM
RE: Flashing updated uboot in Manjaro - by wdt - 05-28-2021, 01:29 PM
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,783 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  I need help deciding if my PBP can be updated ColoBill 4 2,666 06-13-2025, 09:08 PM
Last Post: ColoBill
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,192 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,726 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,218 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 5,557 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 2,881 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,068 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 9,151 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 2,671 12-07-2023, 03:11 PM
