Manjaro Update Broke QT5
this is a known issue, and goes all the way up to the packages from Arch ARM. Easiest solution is to install downgrade and use sudo downgrade package(s) to revert back to previously working versions.
Manjaro Update Broke QT5 - by pete - 02-04-2020, 06:55 AM
RE: Manjaro Update Broke QT5 - by tophneal - 02-04-2020, 07:26 AM
RE: Manjaro Update Broke QT5 - by as400 - 02-04-2020, 07:36 AM
RE: Manjaro Update Broke QT5 - by pete - 02-05-2020, 12:07 AM
RE: Manjaro Update Broke QT5 - by pete - 02-05-2020, 01:23 AM
RE: Manjaro Update Broke QT5 - by pete - 02-06-2020, 01:24 AM
  Manjaro Sway Theme Broken Eighty8 1 312 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 354 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,788 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 368 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,211 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,292 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 439 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 933 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,046 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,011 08-21-2023, 09:08 PM
