kernel build script for latest mainline manjaro kernel
#40
(06-26-2020, 01:20 PM)xmixahlx Wrote: FIRST that won't work, you need an uncompressed Image to boot. the appropriate make config is: (i'll update the script.)
make -j `nproc` INITRD=yes KBUILD_IMAGE=arch/arm64/boot/Image binrpm-pkg
you can skip the rebuild by:
delete the old rpm packages from filesystem
uninstall the old rpm packages
cd to upstream/linux-5.7 and execute that make command above ^
afterwards:
append -5.5.0-pbpro-opensuse-5.5.0 to your old dtb file in /boot (or something like .bak/.old/whatever)
copy the new dtb from the kernel directory to /boot
edit the extlinux file to reflect the new names
you don't need maxcpus=4 in the uboot config for 5.7
make sure you have a verified working sdcard install before you do this for an emergency recovery method.
That worked! Thanks.
opensuse:~> uname -a
Linux opensuse 5.7.0-0.38-1-pinebookpro-hwaccel #2 SMP PREEMPT Fri Jun 26 19:30:14 EDT 2020 aarch64 aarch64 aarch64 GNU/Linux
One thing I noticed is that at boot the brightness is very low.  Will take a look at the post install script for brightness and boot script  (probably boot is fine to leave like it is).
RE: kernel build script for latest mainline manjaro kernel - by ric - 06-26-2020, 06:07 PM
  Building PPSSPP with Manjaro AUR LivingLinux 0 1,167 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 13,597 07-31-2021, 04:44 AM
Last Post: jiyong
  Make your own Manjaro image flatulent_piney 0 3,252 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 7,147 10-24-2020, 06:38 AM
Last Post: pineitup
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 3,442 10-02-2020, 12:20 PM
Last Post: wrzomar
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 2,918 08-02-2020, 06:57 AM
Last Post: dieselnutjob
  Installing WPS Office on Manjaro brent.thierens 5 9,781 07-13-2020, 03:13 AM
Last Post: brent.thierens
  full disk encryption with luks on manjaro xfce limxr 48 68,047 07-09-2020, 07:27 AM
Last Post: JtR
  Is there a MMC upgrade instruction from debian-mate to manjaro factory (20.06)? pljanson 4 7,973 06-23-2020, 12:41 AM
Last Post: pljanson
  mesa-git build script for latest panfrost xmixahlx 28 47,705 06-11-2020, 11:16 PM
Last Post: xmixahlx
