Issues with "recovery" button
Thanks for all the suggestions! I will give it another try. Smile
I am try to to this as I flashed a misconfigured bootloader to my eMMC card. As the boot order is hardcoded on to the SoC, the only way that I can boot an OS right now is with the eMMC disabled. I found that if I can reprogram the SPI to boot the SD first, then I should be able to mount and access the eMMC. The problem is that the mtd-utils toolkit is not able to wright to the SPI flash (as mtd0) as it is locked, and I am not able to do a unlock. I get "error 110-time out" when ever I try to modify it. In essence, its stuck in read-only mode. I was hopping that I would be able to access it with the tools from rock-chip, but have had no luck so far with that. If all else fails I have an eMMC reader on order, how ever I would still like to be able to connect to it.
Anyone else have trouble with the SPI Flash module? I have no problems on my RockPro64...
Issues with "recovery" button - by LANStrider - 01-26-2020, 09:54 AM
RE: Issues with "recovery" button - by xmixahlx - 01-27-2020, 02:08 AM
RE: Issues with "recovery" button - by danielt - 01-27-2020, 08:42 AM
RE: Issues with "recovery" button - by ElektromAn - 01-27-2020, 08:55 AM
RE: Issues with "recovery" button - by LANStrider - 01-27-2020, 03:53 PM
RE: Issues with "recovery" button - by LANStrider - 01-27-2020, 07:28 PM
RE: Issues with "recovery" button - by as400 - 01-28-2020, 03:51 AM
RE: Issues with "recovery" button - by LANStrider - 01-28-2020, 04:12 PM
RE: Issues with "recovery" button - by as400 - 01-29-2020, 11:36 AM
RE: Issues with "recovery" button - by clover - 01-30-2020, 12:27 AM
RE: Issues with "recovery" button - by clover - 01-30-2020, 12:25 PM
RE: Issues with "recovery" button - by clover - 01-30-2020, 05:25 PM
  Issues with T-Mobile Home Internet? skinnyonthebebop 3 1,101 10-17-2023, 07:42 AM
Last Post: skinnyonthebebop
  Got a PBP - batch(August/September) and the audio is not good(2 big issues) crazyquark 2 1,506 10-01-2022, 10:16 AM
Last Post: crazyquark
  MiniConda Install Issues nixyhustle 0 799 09-16-2022, 10:06 PM
Last Post: nixyhustle
  new PBP issues jpjnh 9 3,925 08-22-2022, 07:26 AM
  Issues with External Display After Recent Update reundo 0 1,382 11-18-2021, 06:37 PM
Last Post: reundo
  HArdware issues while charging user18130814200115 2 2,842 05-01-2021, 04:13 AM
Last Post: gabeeg
  Issues with chromium-docker PVD 4 6,426 12-17-2020, 10:11 PM
Last Post: warehouses
  App installation issues on PBP pineitup 0 1,698 10-21-2020, 06:23 PM
Last Post: pineitup
  issues with keyboard/trackpad in Manjaro, can't test other OSs joshw 11 12,893 06-25-2020, 08:11 AM
Last Post: joshw
  Intermittent Boot Issues MrRoosevelt 19 18,508 06-21-2020, 06:45 AM
Last Post: khanku
