Chrome settings that's with default Debian install
I fixed this problem by removing the flags from the Chromium properties icon located in the tray at the  bottom of the screen.  You can test this by launching Chromium from the command line in a terminal as follows:
rock@Debian-Desktop:~$ chromium-browser %U
However, when you launch Chromium this way you can't login to Gmail or other Google apps.  To do this you launch Chromium as follows:
rock@Debian-Desktop:~$ chromium-browser  --user-agent="Mozilla/5.0 (X11; CrOS armv7l 6946.63.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.130 Safari/537.36" . Unfortunately, Settings won't work when launched this way.
Hope this helps.
RE: Chrome settings that's with default Debian install - by hpc@scale - 01-22-2020, 10:58 AM
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,941 08-03-2023, 03:30 PM
  Followed the blog post to install Fedora: PBP not booting anymore koenigs 6 1,929 06-01-2023, 10:58 AM
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 321,469 05-12-2023, 06:09 AM
Last Post: korreckj328
  Installing Debian using files only from debian.org and encrypted root filesystem omarcomputing 0 798 10-08-2022, 11:03 AM
Last Post: omarcomputing
  Use SD to install new OS over pinebook debian Rudy558 9 10,877 09-25-2022, 01:19 AM
Last Post: jackwilson
  MiniConda Install Issues nixyhustle 0 810 09-16-2022, 10:06 PM
Last Post: nixyhustle
  Does anyone know how to install levinsboot on pbp? computerc 0 643 09-05-2022, 03:52 PM
Last Post: computerc
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,440 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Main Stream Debian on Pinebook Pro ? bcnaz 4 3,633 08-22-2021, 09:11 AM
  Flickering black window when opening settings Edgars10 0 1,365 06-06-2021, 05:42 AM
Last Post: Edgars10
