postmarketOS/Alpine edge image for the Pinebook Pro
#48
(05-22-2020, 02:14 AM)pmjohann Wrote:
(05-05-2020, 07:52 PM)digeratus1. Wrote:
(04-29-2020, 03:06 PM)digeratus1. Wrote:
(04-29-2020, 02:29 PM)MartijnBraam Wrote: It's actually the last tab in pavucontrol. It should list the option in the attachment. If that option is not there then somehow it's not loading UCM
Sorry about that. Missed that tab. Yes, looks your like your screenshot. "Play high quality music". I'm going to toggle it off and on to see if it has any effect.
@MartijnBraam is there anything else I can do to get sound to work? I even reinstalled to make sure I didn't do something wrong before but it's still not working. Once I get this working I think I can install this on my EMMC.
I just dd'd it to my eMMC, now the pinebook boots fine from eMMC without SD card, but the keyboard and trackpad are both dead Sad
Tried to attach USB mouse, no luck either.
UPDATE: Now tried to reboot from SD card, same issue!
Maybe there was a hidden partition on the eMMC with built-in firmwares which I got overwritten?
Thanks!
I've been running postmarketOS exclusively since the end of March without issues. Well, one of issue - sound - but that was my fault. Are you using the default image from March? Also, had you already performed the trackpad firmware update to your PBP?
RE: postmarketOS/Alpine edge image for the Pinebook Pro - by digeratus1. - 05-23-2020, 02:39 PM
  Debian on Pinebook Pro u974615 7 1,181 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,681 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,193 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,272 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,564 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,294 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,408 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,519 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,619 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 673 07-13-2023, 05:21 PM
Last Post: owaspfap
