Gentoo on Pinebook Pro RELEASE
#50
Hi!
Happy Gentoo user on a Pinebook Pro:
# neofetch
         -/oyddmdhs+:.                root@pbp
     -odNMMMMMMMMNNmhy+-`             --------
   -yNMMMMMMMMMMMNNNmmdhy+-           OS: Gentoo/Linux aarch64
`omMMMMMMMMMMMMNmdmmmmddhhy/`        Host: Pine64 Pinebook Pro
omMMMMMMMMMMMNhhyyyohmdddhhhdo`      Kernel: 5.12.9-gentoo
.ydMMMMMMMMMMdhs++so/smdddhhhhdm+`    Uptime: 34 secs
oyhdmNMMMMMMMNdyooydmddddhhhhyhNd.   Packages: 868 (emerge)
  :oyhhdNNMMMMMMMNNNmmdddhhhhhyymMh   Shell: bash 5.1.8
    .:+sydNMMMMMNNNmmmdddhhhhhhmMmy   Resolution: 1920x1080
       /mMMMMMMNNNmmmdddhhhhhmMNhs:   Terminal: /dev/pts/0
    `oNMMMMMMMNNNmmmddddhhdmMNhs+`    CPU: (6) @ 1.416GHz
  `sNMMMMMMMMNNNmmmdddddmNMmhs/.      Memory: 137MiB / 3868MiB
/NMMMMMMMMNNNNmmmdddmNMNdso:`
+MMMMMMMNNNNNmmmmdmNMNdso/-
yMMNNNNNNNmmmmmNNMmhs+/-`
/hMMNNNNNNNNMNdhs++/-`
`/ohdmmddhys+++/:.`
# emerge --info
Portage 3.0.19 (python 3.9.5-final-0, default/linux/arm64/17.0, gcc-11.1.0, glibc-2.33, 5.12.9-gentoo aarch64)
System uname: Linux-5.12.9-gentoo-aarch64-with-glibc2.33
KiB Mem:     3961144 total,   3612776 free
KiB Swap:      30220 total,     30220 free
Head commit of repository gentoo: 7ba6fa62d85c26262848d9ed646a297685129057
Head commit of repository audio-overlay: 2f8870b079d0a4d5ad88587dd24718544cda26db
Head commit of repository local: df9092c8b43e63433a2740dad2f61ab234a4ca6d
sh bash 5.1_p8
ld GNU ld (Gentoo 2.36.1 p3) 2.36.1
app-shells/bash:          5.1_p8::gentoo
dev-java/java-config:     2.3.1::gentoo
dev-lang/perl:            5.34.0::gentoo
dev-lang/python:          2.7.18_p10::gentoo, 3.9.5_p2::gentoo, 3.10.0_beta2::gentoo
dev-lang/rust:            1.52.1::gentoo
dev-util/cmake:           3.20.3::gentoo
sys-apps/baselayout:      2.7-r2::gentoo
sys-apps/openrc:          0.43.3::gentoo
sys-apps/sandbox:         2.24::gentoo
sys-devel/autoconf:       2.13-r1::gentoo, 2.69-r5::gentoo
sys-devel/automake:       1.13.4-r2::gentoo, 1.16.3-r1::gentoo
sys-devel/binutils:       2.36.1-r1::gentoo
sys-devel/gcc:            11.1.0::gentoo
sys-devel/gcc-config:     2.4::gentoo
sys-devel/libtool:        2.4.6-r6::gentoo
sys-devel/make:           4.3::gentoo
sys-kernel/linux-headers: 5.12::gentoo (virtual/os-headers)
sys-libs/glibc:           2.33::gentoo
Repositories:
gentoo
    sync-type: git
    sync-uri: git://anongit.gentoo.org/repo/gentoo.git
    priority: -1000
audio-overlay
    sync-type: git
    sync-uri: https://github.com/gentoo-audio/audio-overlay.git
    masters: gentoo
local
    sync-type: git
    sync-uri: /data/nas/xavier/git_repos/local_overlay.git/
    masters: gentoo
crossdev
    location: /data/nas/xavier/portage/pinebook-pro/var/db/repos/crossdev
    masters: gentoo
    priority: 10
ACCEPT_KEYWORDS="arm64 ~arm64"
ACCEPT_LICENSE="@FREE as-is freedist"
CBUILD="aarch64-unknown-linux-gnu"
CFLAGS="-O2 -pipe -fomit-frame-pointer -mlittle-endian -mabi=lp64 -march=armv8-a+crypto+crc -mtune=cortex-a72.cortex-a53"
CHOST="aarch64-unknown-linux-gnu"
CONFIG_PROTECT="/etc /usr/lib64/libreoffice/program/sofficerc /usr/share/config /usr/share/gnupg/qualified.txt"
CONFIG_PROTECT_MASK="/etc/ca-certificates.conf /etc/dconf /etc/env.d /etc/fonts/fonts.conf /etc/gconf /etc/gentoo-release /etc/revdep-rebuild /etc/sandbox.d /etc/terminfo"
CXXFLAGS="-O2 -pipe -fomit-frame-pointer -mlittle-endian -mabi=lp64 -march=armv8-a+crypto+crc -mtune=cortex-a72.cortex-a53"
DISTDIR="/var/portage/distfiles"
EMERGE_DEFAULT_OPTS="--with-bdeps y --quiet-build=n --buildpkg"
ENV_UNSET="CARGO_HOME DBUS_SESSION_BUS_ADDRESS DISPLAY GOBIN GOPATH PERL5LIB PERL5OPT PERLPREFIX PERL_CORE PERL_MB_OPT PERL_MM_OPT XAUTHORITY XDG_CACHE_HOME XDG_CONFIG_HOME XDG_DATA_HOME XDG_RUNTIME_DIR"
FCFLAGS="-O2"
FEATURES="assume-digests binpkg-docompress binpkg-dostrip binpkg-logs binpkg-multi-instance buildpkg candy config-protect-if-modified distlocks ebuild-locks fixlafiles ipc-sandbox merge-sync multilib-strict network-sandbox news parallel-fetch pid-sandbox preserve-libs protect-owned qa-unresolved-soname-deps sandbox sfperms strict unknown-features-warn unmerge-logs unmerge-orphans userfetch userpriv usersandbox usersync xattr"
FFLAGS="-O2"
GENTOO_MIRRORS="http://distfiles.gentoo.org"
LDFLAGS="-Wl,-O1 -Wl,--sort-common -Wl,--hash-style=gnu -Wl,--as-needed"
MAKEOPTS="-j7 -l7"
PKGDIR="/var/portage/packages"
PORTAGE_CONFIGROOT="/"
PORTAGE_RSYNC_OPTS="--recursive --links --safe-links --perms --times --omit-dir-times --compress --force --whole-file --delete --stats --human-readable --timeout=180 --exclude=/distfiles --exclude=/local --exclude=/packages --exclude=/.git"
PORTAGE_TMPDIR="/var/tmp"
USE="X a52 aac acpi alsa apng arm64 bluetooth branding bzip2 cairo cli crypt cryptsetup css cups dbus dlna dri dssi dts dvb exif flac gif glamor gles2 gnome-keyring gpm gtk gudev gui iconv joystick jpeg lcms libcanberra libglvnd libinput libnotify libsamplerate libtirpc mad matroska mng mp3 mpeg mtp natspec ncurses network nls nptl ocr ogg openal opengl openmp openssl opus osc pango pcre pdf png pnm printsupport qt5 readline sane sdl seccomp sna sndfile snmp spell split-usr sqlite ssl startup-notification svg system-bootstrap system-llvm tcpd threads tiff truetype udev unicode upnp usb uxa vorbis wmf x264 xattr xcb xinerama xml xosd xv xvid zlib" ADA_TARGET="gnat_2018" APACHE2_MODULES="authn_core authz_core socache_shmcb unixd actions alias auth_basic authn_alias authn_anon authn_dbm authn_default authn_file authz_dbm authz_default authz_groupfile authz_host authz_owner authz_user autoindex cache cgi cgid dav dav_fs dav_lock deflate dir disk_cache env expires ext_filter file_cache filter headers include info log_config logio mem_cache mime mime_magic negotiation rewrite setenvif speling status unique_id userdir usertrack vhost_alias" CALLIGRA_FEATURES="karbon sheets words" COLLECTD_PLUGINS="df interface irq load memory rrdtool swap syslog" CPU_FLAGS_ARM="edsp thumb thumb2 v4 v5 v6 v7 v8 vfp vfp-d32 vfpv3 vfpv4" ELIBC="glibc" GPSD_PROTOCOLS="ashtech aivdm earthmate evermore fv18 garmin garmintxt gpsclock greis isync itrax mtk3301 nmea ntrip navcom oceanserver oldstyle oncore rtcm104v2 rtcm104v3 sirf skytraq superstar2 timing tsip tripmate tnt ublox ubx" KERNEL="linux" L10N="fr nl" LCD_DEVICES="bayrad cfontz cfontz633 glk hd44780 lb216 lcdm001 mtxorb ncurses text" LIBREOFFICE_EXTENSIONS="presenter-console presenter-minimizer" LUA_SINGLE_TARGET="lua5-1" LUA_TARGETS="lua5-1" OFFICE_IMPLEMENTATION="libreoffice" PHP_TARGETS="php7-3 php7-4" POSTGRES_TARGETS="postgres10 postgres11" PYTHON_SINGLE_TARGET="python3_9" PYTHON_TARGETS="python3_9" RUBY_TARGETS="ruby26" USERLAND="GNU" VIDEO_CARDS="panfrost" XTABLES_ADDONS="quota2 psd pknock lscan length2 ipv4options ipset ipp2p iface geoip fuzzy condition tee tarpit sysrq proto steal rawnat logmark ipmark dhcpmac delude chaos account"
Unset:  CC, CPPFLAGS, CTARGET, CXX, INSTALL_MASK, LANG, LC_ALL, LINGUAS, PORTAGE_BINHOST, PORTAGE_BUNZIP2_COMMAND, PORTAGE_COMPRESS, PORTAGE_COMPRESS_FLAGS, PORTAGE_RSYNC_EXTRA_OPTS, RUSTFLAGS
I use Gento since 2004, on all my machines/servers, this is not the first ARM system I have, I also run Gentoo on rpi1, helios4 and helios64 (also a RK3399).
Kind regards,
Xavier Miller.
Gentoo on Pinebook Pro RELEASE - by jannik2099 - 01-13-2020, 10:47 AM
RE: Gentoo on Pinebook Pro RELEASE - by Arwen - 01-13-2020, 07:12 PM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-15-2020, 11:20 AM
RE: Gentoo on Pinebook Pro RELEASE - by VoxUnius - 01-15-2020, 05:34 PM
RE: Gentoo on Pinebook Pro RELEASE - by VoxUnius - 01-18-2020, 05:13 PM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-19-2020, 07:57 AM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-21-2020, 12:34 AM
RE: Gentoo on Pinebook Pro RELEASE - by as400 - 01-21-2020, 01:55 AM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-21-2020, 11:59 PM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-23-2020, 01:31 AM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-24-2020, 09:13 AM
RE: Gentoo on Pinebook Pro RELEASE - by Arwen - 01-29-2020, 07:38 PM
RE: Gentoo on Pinebook Pro RELEASE - by madalin - 02-01-2020, 11:00 AM
RE: Gentoo on Pinebook Pro RELEASE - by madalin - 02-02-2020, 09:44 AM
RE: Gentoo on Pinebook Pro RELEASE - by PakoSt - 02-04-2020, 09:59 AM
RE: Gentoo on Pinebook Pro RELEASE - by necrose99 - 02-12-2020, 05:59 PM
RE: Gentoo on Pinebook Pro RELEASE - by necrose99 - 02-15-2020, 07:45 PM
RE: Gentoo on Pinebook Pro RELEASE - by larsgn - 02-25-2020, 08:58 AM
Gentoo on Pinebook Pro RELEASE - by necrose99 - 03-01-2020, 10:05 AM
RE: Gentoo on Pinebook Pro RELEASE - by rjraymond - 09-18-2020, 11:06 PM
RE: Gentoo on Pinebook Pro RELEASE - by kuleszdl - 01-02-2021, 10:05 PM
RE: Gentoo on Pinebook Pro RELEASE - by wdt - 01-03-2021, 06:21 AM
RE: Gentoo on Pinebook Pro RELEASE - by alchemist - 06-08-2021, 12:45 PM
RE: Gentoo on Pinebook Pro RELEASE - by glesker - 10-05-2021, 08:16 AM
RE: Gentoo on Pinebook Pro RELEASE - by kebab - 11-26-2023, 06:36 PM
RE: Gentoo on Pinebook Pro RELEASE - by tllim - 12-08-2023, 11:25 PM
  Debian on Pinebook Pro u974615 7 1,321 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,834 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,243 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,341 12-11-2023, 03:47 AM
Last Post: calinb
  Boot Order in Pinebook Pro food 8 1,345 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,492 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,555 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,669 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 689 07-13-2023, 05:21 PM
Last Post: owaspfap
  OpenCL on pinebook Pro Bram 2 1,026 06-30-2023, 08:50 PM
Last Post: scurrvy2020
