Gentoo on Pinebook Pro RELEASE
#19
(01-21-2020, 10:44 AM)jannik2099 Wrote: @delcaran , sorry, stuff broke because a dependency changed in the repo. There's not really an automated way to do the required things so I manually have to adapt the script every time this happens - I should probably set up an automated test suite
I tried to reproduce this with both the systemd and openrc tarball but couldn't do that, perhaps the repo was updated again? Either way, I've updated the script to run dispatch-conf , which will prompt you to manually merge these changes should they be required (press m, then r, then u). Please download the script again and try in a fresh tarball
Thanks man, I know keeping track of depencies is a real pain, as a Slackware user and professional developer, I share a lot of that pain Smile
Anyway, I'll keep track of your repo for all the other changes you've main and try something after work.
Thanks again!
Gentoo on Pinebook Pro RELEASE - by jannik2099 - 01-13-2020, 10:47 AM
RE: Gentoo on Pinebook Pro RELEASE - by Arwen - 01-13-2020, 07:12 PM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-15-2020, 11:20 AM
RE: Gentoo on Pinebook Pro RELEASE - by VoxUnius - 01-15-2020, 05:34 PM
RE: Gentoo on Pinebook Pro RELEASE - by VoxUnius - 01-18-2020, 05:13 PM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-19-2020, 07:57 AM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-21-2020, 12:34 AM
RE: Gentoo on Pinebook Pro RELEASE - by as400 - 01-21-2020, 01:55 AM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-21-2020, 11:59 PM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-23-2020, 01:31 AM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-24-2020, 09:13 AM
RE: Gentoo on Pinebook Pro RELEASE - by Arwen - 01-29-2020, 07:38 PM
RE: Gentoo on Pinebook Pro RELEASE - by madalin - 02-01-2020, 11:00 AM
RE: Gentoo on Pinebook Pro RELEASE - by madalin - 02-02-2020, 09:44 AM
RE: Gentoo on Pinebook Pro RELEASE - by PakoSt - 02-04-2020, 09:59 AM
RE: Gentoo on Pinebook Pro RELEASE - by necrose99 - 02-12-2020, 05:59 PM
RE: Gentoo on Pinebook Pro RELEASE - by necrose99 - 02-15-2020, 07:45 PM
RE: Gentoo on Pinebook Pro RELEASE - by larsgn - 02-25-2020, 08:58 AM
Gentoo on Pinebook Pro RELEASE - by necrose99 - 03-01-2020, 10:05 AM
RE: Gentoo on Pinebook Pro RELEASE - by rjraymond - 09-18-2020, 11:06 PM
RE: Gentoo on Pinebook Pro RELEASE - by kuleszdl - 01-02-2021, 10:05 PM
RE: Gentoo on Pinebook Pro RELEASE - by wdt - 01-03-2021, 06:21 AM
RE: Gentoo on Pinebook Pro RELEASE - by alchemist - 06-08-2021, 12:45 PM
RE: Gentoo on Pinebook Pro RELEASE - by glesker - 10-05-2021, 08:16 AM
RE: Gentoo on Pinebook Pro RELEASE - by kebab - 11-26-2023, 06:36 PM
RE: Gentoo on Pinebook Pro RELEASE - by tllim - 12-08-2023, 11:25 PM
  Debian on Pinebook Pro u974615 7 1,220 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,693 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,202 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,285 12-11-2023, 03:47 AM
Last Post: calinb
  Boot Order in Pinebook Pro food 8 1,301 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,423 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,529 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,633 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 674 07-13-2023, 05:21 PM
Last Post: owaspfap
  OpenCL on pinebook Pro Bram 2 1,011 06-30-2023, 08:50 PM
Last Post: scurrvy2020
