Gentoo on Pinebook Pro RELEASE
Sorry you two, seems like I hadn't set the email notification correctly.
(01-15-2020, 11:20 AM)delcaran Wrote: Hello! I'm a fresh owner of the Pinebook Pro and I would like to test Gentoo with full disk encryption on it.
It's the first time I install Gentoo without and ISO, so I need to be assured on the correct procedure.
Is the following correct?
- download a stage3 tarball
- can I use the hardened musl or should I stick with "standard" musl?
- partition sdcard
- mount sdcard
- unpack the stage3 on the sd
- use your script on the unpacked stage3
- proceed with chroot and installation
- reboot and login on "live" system
- partition pinebook for full disk encryption as described in https://wiki.gentoo.org/wiki/Full_Disk_E...Simplified
- repeat mount/download/unpack/script/compile
- enjoy
I have a 15+ years experience with Slackware, so be technical if you must Wink
Thanks for the answer and your work!
First I should note that an encrypted boot partition is not possible, but encrypted root works just fine, that's what I'm using right now.
I have never used a hardened profile nor do I know the differences here, sorry.
You set up the encryption during partitioning. For the initramfs you should use dracut with `dracut -m "crypt drm i18n base"` (and your filesystem if you made it a module, and lvm if you use it) - all other initramfs tools have failed me thus far in getting the display to work. The Kernel commandline should include console=tty1 rd.luks.uuid=... and after that root=UUID=...
The script should only be run once directly after entering the chroot, not again on the live system. Don't forget to install the packages mentioned in the README
(01-15-2020, 05:34 PM)VoxUnius Wrote: Hmm. Interesting. I've been playing with Gentoo on PBP for months but it still has the same issues it had in the beginning. The biggest ones would be: freezing LibreOffice that uses 100% CPU, and flickering widgets (checkboxes, in particular). Also, not sure if it uses video acceleration, looks like it is not. I used Manjaro kernel too, even tried the same config. I was hoping the problem lied in kernel/mesa/drm, but newer version didn't help.
Perhaps you were using the GL qt backend, and not gles2? Manjaro uses the fbturbo xorg driver, without it GL is unusable. My script sets up gles2 which should be faster than manjaro. I just opened libreoffice and it feels very responsive.
Gentoo on Pinebook Pro RELEASE - by jannik2099 - 01-13-2020, 10:47 AM
RE: Gentoo on Pinebook Pro RELEASE - by Arwen - 01-13-2020, 07:12 PM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-15-2020, 11:20 AM
RE: Gentoo on Pinebook Pro RELEASE - by VoxUnius - 01-15-2020, 05:34 PM
RE: Gentoo on Pinebook Pro RELEASE - by jannik2099 - 01-18-2020, 01:24 PM
RE: Gentoo on Pinebook Pro RELEASE - by VoxUnius - 01-18-2020, 05:13 PM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-19-2020, 07:57 AM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-21-2020, 12:34 AM
RE: Gentoo on Pinebook Pro RELEASE - by as400 - 01-21-2020, 01:55 AM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-21-2020, 11:59 PM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-23-2020, 01:31 AM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-24-2020, 09:13 AM
RE: Gentoo on Pinebook Pro RELEASE - by Arwen - 01-29-2020, 07:38 PM
RE: Gentoo on Pinebook Pro RELEASE - by madalin - 02-01-2020, 11:00 AM
RE: Gentoo on Pinebook Pro RELEASE - by madalin - 02-02-2020, 09:44 AM
RE: Gentoo on Pinebook Pro RELEASE - by PakoSt - 02-04-2020, 09:59 AM
RE: Gentoo on Pinebook Pro RELEASE - by necrose99 - 02-12-2020, 05:59 PM
RE: Gentoo on Pinebook Pro RELEASE - by necrose99 - 02-15-2020, 07:45 PM
RE: Gentoo on Pinebook Pro RELEASE - by larsgn - 02-25-2020, 08:58 AM
Gentoo on Pinebook Pro RELEASE - by necrose99 - 03-01-2020, 10:05 AM
RE: Gentoo on Pinebook Pro RELEASE - by rjraymond - 09-18-2020, 11:06 PM
RE: Gentoo on Pinebook Pro RELEASE - by kuleszdl - 01-02-2021, 10:05 PM
RE: Gentoo on Pinebook Pro RELEASE - by wdt - 01-03-2021, 06:21 AM
RE: Gentoo on Pinebook Pro RELEASE - by alchemist - 06-08-2021, 12:45 PM
RE: Gentoo on Pinebook Pro RELEASE - by glesker - 10-05-2021, 08:16 AM
RE: Gentoo on Pinebook Pro RELEASE - by kebab - 11-26-2023, 06:36 PM
RE: Gentoo on Pinebook Pro RELEASE - by tllim - 12-08-2023, 11:25 PM
  Debian on Pinebook Pro u974615 7 1,063 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,622 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,163 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,237 12-11-2023, 03:47 AM
Last Post: calinb
  Boot Order in Pinebook Pro food 8 1,263 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,306 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,489 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,596 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 667 07-13-2023, 05:21 PM
Last Post: owaspfap
  OpenCL on pinebook Pro Bram 2 997 06-30-2023, 08:50 PM
Last Post: scurrvy2020
