USB-C charging
(01-10-2020, 05:24 AM)fpex73 Wrote: I just got my pine book pro, and I tried to connect it to a power bank (one that works with things like iPad and alike).\The pine book was saying charing but actually the battery was discharging.
I am now trying to charge with the provided supplier, but I wonder if the PBP is compatible to powerbanks at all no or there is an issue and I need to open my PBP to check out things.
Thanks.
It can charge from a powerbank capable of delivering at least 2A 5V. But at 10W it will charge very slowly. Also, which OS are you using? did you update it? etc.,
If you're planning to open your PBP - make sure to read the wiki section on opening and closing it.
USB-C charging - by fpex73 - 01-10-2020, 05:24 AM
RE: USB-C charging - by Luke - 01-10-2020, 05:36 AM
RE: USB-C charging - by danielt - 01-10-2020, 05:39 AM
RE: USB-C charging - by fpex73 - 01-10-2020, 06:11 AM
RE: USB-C charging - by ElektromAn - 01-11-2020, 06:32 AM
RE: USB-C charging - by fpex73 - 01-11-2020, 08:05 AM
RE: USB-C charging - by ElektromAn - 01-11-2020, 08:52 AM
RE: USB-C charging - by zaius - 01-11-2020, 02:17 PM
RE: USB-C charging - by fpex73 - 01-11-2020, 08:59 AM
RE: USB-C charging - by fpex73 - 01-14-2020, 04:51 AM
RE: USB-C charging - by ElektromAn - 01-15-2020, 11:38 AM
Photo P{inebook Pro not charging Ome Ko 6 2,003 11-09-2023, 03:29 PM
Last Post: tomekdev
  Pine Book Pro Charging Problems balin 7 6,926 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,538 02-22-2022, 11:20 AM
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 4,319 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  HArdware issues while charging user18130814200115 2 2,837 05-01-2021, 04:13 AM
Last Post: gabeeg
  PineBookPro does not charging floppy_rofling 0 1,652 02-03-2021, 05:29 AM
Last Post: floppy_rofling
  Screen flicker with USB-C charging bchenlee609 5 5,886 01-25-2021, 08:48 PM
Last Post: bchenlee609
  USB-C Charging on the PBP? Paulie420 33 35,907 12-12-2020, 02:20 PM
Last Post: wrzomar
  Charging via USB-C Port tyha 15 20,143 07-22-2020, 08:15 PM
Last Post: iscmob
  Battery not charging via AC Adapter laissezfarrell 1 3,137 05-30-2020, 06:05 PM
