01-07-2020, 09:18 AM
(01-06-2020, 03:24 PM)hibbelig Wrote:Fantastic! I'm glad this worked, as it ought to. I'm still awaiting my PBP delivery, so I've had to rely on what I read in these forums, along with my Debian/Ubuntu experience over the years.(01-06-2020, 09:45 AM)Jeremiah Cornelius Wrote: I assume that this should work as expected. The kernel and headers would be excluded by a regular apt-get dist upgrade, after changing sources.list I think.
The best course would be to test this on a separate SD card, and then detail your experience for the community on Daniel's original thread. Then you could repro what works on your main install.
I've gone through the process and it worked nicely.
Because releases other than sid have "-proposed-updates" and "-security" and "-backports", but sid has none of these, I commented out those lines in "sources.list". So the bottom line was that there are now only two active lines in my sources:
Code:deb http://deb.debian.org/debian sid main contrib non-free
deb http://download.opensuse.org/repositories/home:/danielthompson/Debian_Unstable ./
Of course, the first line was from "/etc/apt/sources.list" and the second line was from the extra file that Daniel's installer created.
"apt full-upgrade" wanted to update about 175 packages, it seemed to be fairly safe. System is back running as normal.
< SNIP >
— Jeremiah Cornelius
"Be the first person not to do something, that no one has thought of not doing before’’
