Networking Issues
(01-10-2020, 07:46 PM)a0kami Wrote:
(01-03-2020, 01:25 PM)rleasle Wrote: Well, that was fun. Turns out that the DHCP client took precedence  over the default gateway for my home network. Once I disabled that, everything came up correctly. I guess I'm the only one here stubborn enough to use static IPs?
I'm not sure I understand how fixed but I'm having the exact same host not resolving issue over wifi.
I connect to a shitty wifi extender and I've had a friend having issues as well (he was using x86 though). :/
Anyway in the meantime I borrowed a usb-to-ethernet adapter, but may I kindly ask you could fill me in on what exactly is the issue and how to troubleshoot ? Smile
TL;DR - It's probably a configuration issue. Check Network Manager for your wifi setup, try the 'ping' command to test DNS and routing.
It's not about the connection (unless you have the wrong wifi password or security settings), it's about how networking is configured. So DNS (name server) and default routing. Not sure how much you know about networking (not sure how much I know). If it's a DNS problem, you can get to a remote host by IP address, but not by name. When I was having my problem, I used the command
$ ping github.com
and the system would try the correct IP address. So DNS was working (the ping didn't work because of routing issues). If DNS was messed up, it would have told me "name or service not known". Even with DNS messed up, if the routing is correct, you can ping the IP directly
$ ping 192.30.255.112
You can look at or change the DNS settings from the Network Manager. It should also show up in the file /etc/resolv.conf
For the routing issue I had, I used the route command:
$ route -n
Destination    Gateway        Genmask        Flags    Metric    Ref Use    Iface
0.0.0.0        0.0.0.0        0.0.0.0        U    302    0   0    wlan0
169.254.0.0    0.0.0.0        255.255.0.0    U    302    0   0    wlan0
The above output was what it looked like when I was having my problems. That netmask value (255.255.0.0) was only allowing me to access part of the internet.
You can also check the configuration that Network Manager set up from the command line (here, I've X-ed out my actual values):
$ sudo ifconfig wan0
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet xx.xx.xx.xx  netmask 255.255.255.0  broadcast xx.xx.xx.255
        inet6 xxxx::xxxx:xxxx:xxxx:xxxx  prefixlen 64  scopeid 0x20<link>
        ether xx:xx:xx:xx  txqueuelen 1000  (Ethernet)
        RX packets 253663  bytes 334990443 (319.4 MiB)
        RX errors 0  dropped 57  overruns 0  frame 0
        TX packets 135146  bytes 13434493 (12.8 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
If the interface doesn't say UP, you're not actually connected.
Hope something here helps.
Networking Issues - by rleasle - 01-01-2020, 08:25 PM
RE: Networking Issues - by rleasle - 01-03-2020, 01:25 PM
RE: Networking Issues - by a0kami - 01-10-2020, 07:46 PM
RE: Networking Issues - by rleasle - 01-11-2020, 10:56 AM
RE: Networking Issues - by gandlers - 01-11-2020, 07:14 PM
RE: Networking Issues - by rleasle - 01-12-2020, 09:10 AM
RE: Networking Issues - by a0kami - 01-11-2020, 12:14 PM
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,068 08-21-2023, 09:10 PM
Last Post: vanessadonald
  Hibernation and Speaker Sound Issues, First Month of PBP kebab 7 3,090 11-02-2022, 02:33 PM
Last Post: kebab
  Any chance of fixing the audio issues on the new batch PBP(it can't be just me...) crazyquark 0 785 09-30-2022, 10:15 AM
Last Post: crazyquark
  Fedora 33 to 34 upgrade issues tydeman 2 2,537 12-02-2021, 02:43 AM
Last Post: linuxfreund
  Manjaro Issues: Dark Screen & Font size Sally2 1 3,036 12-19-2020, 03:33 PM
Last Post: wove
  Virtual Desktop Issues (Manjaro KDE) davemaps 1 3,274 08-31-2020, 07:28 PM
Last Post: brad2723
  Boot Manjaro lock screen language and key issues Iiari 0 2,278 08-28-2020, 02:21 AM
Last Post: Iiari
  Kali boot issues wofam 0 1,998 06-18-2020, 09:53 AM
Last Post: wofam
  Focal on Bionic Using Chroot - Chromium / Snapd Issues charlespine 0 1,908 06-03-2020, 06:47 PM
Last Post: charlespine
  Manjaro strange speed issues aaspectre 2 4,233 04-28-2020, 12:45 AM
Last Post: e-minguez
