Samsung 970 EVO SSD 1TB - M.2 NVMe works on workstation but not Pinebook Pro
I have a Samsung 970 EVO SSD 1TB - M.2 NVMe in a SSK Aluminum M.2 NVME external case, see here for the product on Amazon: https://www.amazon.com/gp/product/B07MNF...UTF8&psc=1
I installed the gnome-disks utility on the Pinebook Pro to assist me with this.
NVMe and enclosure work without problem on my workstation running Fedora 30. Format, partition, read, write, all good.
dmesg reports:
[341405.622922] usb 6-2: new SuperSpeed Gen 1 USB device number 6 using xhci_hcd
[341405.635207] usb 6-2: New USB device found, idVendor=152d, idProduct=0562, bcdDevice= 2.06
[341405.635211] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[341405.635214] usb 6-2: Product: SSK Storage
[341405.635215] usb 6-2: Manufacturer: SSK
[341405.635217] usb 6-2: SerialNumber: DF56419883E5B
[341405.823661] usb 6-2: USB controller 0000:0c:00.0 does not support streams, which are required by the UAS driver.
[341405.823667] usb 6-2: Please try an other USB controller if you wish to use UAS.
[341405.823671] usb-storage 6-2:1.0: USB Mass Storage device detected
[341405.824043] scsi host15: usb-storage 6-2:1.0
[341406.842939] scsi 15:0:0:0: Direct-Access     SSK                       0206 PQ: 0 ANSI: 6
[341406.843583] sd 15:0:0:0: Attached scsi generic sg8 type 0
[341409.512535] sd 15:0:0:0: [sdg] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[341409.515399] sd 15:0:0:0: [sdg] Write Protect is off
[341409.515407] sd 15:0:0:0: [sdg] Mode Sense: 53 00 00 08
[341409.518240] sd 15:0:0:0: [sdg] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[341409.528580]  sdg: sdg1
[341409.534874] sd 15:0:0:0: [sdg] Attached SCSI disk
However, the Pinebook Pro recognizes the enclosure when plugged in to a USB 3 port, assigning it the device file /dev/sda, but gnome-disks reports "No Media".  dmesg reports:
[ 1490.403480] usb 2-1.1: new high-speed USB device number 4 using ehci-platform
[ 1490.564908] usb 2-1.1: New USB device found, idVendor=152d, idProduct=0562, bcdDevice= 2.06
[ 1490.565662] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1490.566313] usb 2-1.1: Product: SSK Storage
[ 1490.566693] usb 2-1.1: Manufacturer: SSK
[ 1490.567050] usb 2-1.1: SerialNumber: DF56419883E5B
[ 1490.569695] scsi host0: uas
[ 1490.571524] scsi 0:0:0:0: Direct-Access     SSK                       0206 PQ: 0 ANSI: 6
[ 1490.573978] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1499.433316] sd 0:0:0:0: [sda] Unit Not Ready
[ 1499.433767] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 1499.434347] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1499.435414] sd 0:0:0:0: [sda] Read Capacity(16) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 1499.436252] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 1499.436829] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1499.437890] sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 1499.438720] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 1499.439285] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1499.440892] sd 0:0:0:0: [sda] 0 512-byte logical blocks: (0 B/0 B)
[ 1499.441442] sd 0:0:0:0: [sda] 0-byte physical blocks
[ 1499.442261] sd 0:0:0:0: [sda] Test WP failed, assume Write Enabled
[ 1499.443012] sd 0:0:0:0: [sda] Asking for cache data failed
[ 1499.443537] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 1499.444514] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (0 bytes)
[ 1499.485275] sd 0:0:0:0: [sda] Unit Not Ready
[ 1499.485675] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 1499.486252] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1499.487290] sd 0:0:0:0: [sda] Read Capacity(16) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 1499.488131] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 1499.488711] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1499.489911] sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 1499.490756] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 1499.491336] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 1499.494885] sd 0:0:0:0: [sda] Attached SCSI disk
I note that there is a package named nvme-cli, is this necessary?
Same problem with the default operating system, and with an install of the Mandriva KDE image.
Is this the problem: [ 1499.490756] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current], is the Pinebook Pro not capable of supplying sufficient current for this device?
Thanks for any ideas offered!
Samsung 970 EVO SSD 1TB - M.2 NVMe works on workstation but not Pinebook Pro - by mgchristensen - 12-28-2019, 02:10 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 666 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 369 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 312 02-17-2024, 07:06 PM
  New Working nVME gilwood 0 249 02-12-2024, 08:46 AM
Last Post: gilwood
  Pinebook Pro charging issues tomekdev 1 655 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,158 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,331 09-13-2023, 03:43 AM
Last Post: k3dAR
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,587 04-04-2023, 12:16 PM
Last Post: globaltree
  PineBook Pro dead ottahe 9 6,102 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,508 12-27-2022, 03:31 PM
Last Post: samtux
