default os: loop while login as rock
< SNIP >
Quote:Anyway this is not that important since you mentioned :
$ sudo mrfixit_update.sh
So I can still update the system as my other user.
thanks again. All the best for 2020!
Regards, Adrian
It's a good idea to add sudo and include your user by group membership to sudoers. If for nothing else but these occasions.
If you want to then change a forgotten root user password, "sudo su -" gets you a root shell with environment, and then a regular "passwd" will change root, without asking for previous shadow entry.
This also helps when you are running things that sudo has difficulty with - such as some scripts. I hate editing these to prepend extra "sudo" commands to lines.
— Jeremiah Cornelius
RE: default os: loop while login as rock - by Jeremiah Cornelius - 12-31-2019, 11:51 AM
  No Sound on Default Manjaro KDE carlosqueso 4 5,154 04-01-2021, 07:17 AM
Last Post: carlosqueso
  Graphical login hanging after password entry mhill8 2 3,374 03-29-2021, 08:32 AM
Last Post: jacksonliam341
  PBP Went Blank After Login iscmob 2 2,997 12-07-2020, 09:28 AM
Last Post: iscmob
  Pinebook Pro Won't Accept Login GFreeman 16 16,539 09-03-2020, 11:44 AM
  Suspend with NVME not working - Default Debian appdev46 5 8,667 07-14-2020, 01:53 PM
Last Post: Jeremiah Cornelius
  Login screen issue. LinuXchoicE 2 4,136 07-07-2020, 09:06 AM
Last Post: LinuXchoicE
  Default OS update log Luke 194 277,901 06-11-2020, 11:25 PM
Last Post: xmixahlx
  OEM Script - Factory Default xmark 0 1,906 06-07-2020, 06:51 AM
Last Post: xmark
  How do you upgrade Chromium on default Debian that came with my PBP james64 6 7,940 05-26-2020, 07:21 AM
Last Post: User 6582
  Stuck on login screen Kscott6969 0 1,924 04-20-2020, 10:58 PM
Last Post: Kscott6969
