An unofficial Debian Installer for Pinebook Pro
(08-02-2020, 02:18 PM)ThatGeoGuy Wrote: I've made a terrible mistake and installed the stock debian kernel, and now my system boots to a black screen.
Does anyone know how to pull up the GRUB menu from uboot so I can switch back over to the correct kernel?
U-Boot presents its menu over the serial port. To talk to it, you'll need a 3.3V serial interface that can do 1.5Mbaud, which you can plug it into the PBP's audio port. You'll also need to flip the switch on the PBP's mainboard that enables the serial port.
Note that it's really easy to end up with a 5V serial adapter. The one I bought from the PINE store ended up being 5V, and caused horrible problems when I tried to actually use it. I tried another adapter from a different manufacturer, and it turned out to be 5V as well. (In both cases, the part was advertised as 3.3V.) At that point, I ran out of money to keep trying to find a 3.3V adapter and just... used other means of debugging.
If you don't already have a fast 3.3V serial interface available, and either an adapter or some cable-making experience, you're probably better off making an install of some bootable Linux to an SD card, chrooting into your main system, and removing the stock kernel package. (Assuming you're running from the eMMC.)
First boot - by JaredT66 - 05-19-2020, 09:49 AM
RE: First boot - by carletes - 05-19-2020, 01:35 PM
RE: An unofficial Debian Installer for Pinebook Pro - by Solra Bizna - 08-03-2020, 03:44 AM
  Debian on Pinebook Pro u974615 7 1,322 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,834 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,243 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,341 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,013 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,345 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,158 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,634 09-07-2023, 09:38 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,495 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,555 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
