An unofficial Debian Installer for Pinebook Pro
(04-30-2020, 09:51 AM)Jeremiah Cornelius Wrote:
(04-30-2020, 09:35 AM)jazzmans Wrote: Hi all!
I'm  a long time debian user,  (since Woody!)  but know 0 about git, and although I'm fairly bash savvy, I'm not a coder.
I went to the git page, downloaded/cloned the entire thing to ~/filename/pinebook-pro-debian-installer using the clone/download button in firefox,   but when I run (either as user or root) from within the correct directory ./install-debian,
it errors out immediately with "fatal: Not a git repository (or any of the parent directories): .git"
I'm doing this from the pinebook pro, running the default oldstable debian installation it came with, fully updated via apt.
As should be obvious, I'm not git savvy in the slightest, and the entire boot process of arm confuses me.
Can anyone assist me in getting this process going to install unstable onto an sdcard?
TIA.
Yes, to get a proper build tree, you need to clone the git repository. The download buttons work for getting binaries and docs, but not for checking out, etc.
It's pretty simple. Make sure you have git locally (sudo apt install git).
At a bash prompt, in the parent directory of your choice (I use ~/build) it's as simple as:
$ git clone https://github.com/daniel-thompson/pineb...-installer
There's a lot more to git that can eventually be learned, if you like. Labeled branches are handy at times, and the ability to sync local changes. But simple fetching of build trees can almost start and end with 'git clone'.
Thank you sir,  after reading more, I figured this out, (finally) and now the installation fails at
dd: failed to open 'bootloader/pinebook/filesystem/idbloader.img': No such file or directory
Suggestions from here?
ps,  audiofool here,  I adore brian Eno, and have everything he's ever composed.
[edit may 20]
none of the above problems are problems with the installer now.  probably user error
currently on 'installing packages' on installer.[end edit]
RE: An unofficial Debian Installer for Pinebook Pro - by jazzmans - 04-30-2020, 09:55 AM
First boot - by JaredT66 - 05-19-2020, 09:49 AM
RE: First boot - by carletes - 05-19-2020, 01:35 PM
  Debian on Pinebook Pro u974615 7 1,335 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,837 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,245 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,342 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,037 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,354 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,175 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,644 09-07-2023, 09:38 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,499 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,556 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
Users browsing this thread: 8 Guest(s)
