An unofficial Debian Installer for Pinebook Pro
(04-05-2020, 08:53 AM)moonwalkers Wrote: You should first try to use apt, reboot, and run `uname -a`. It's easy, it's quick, and it typically carries no more risk than manually copying the bootloader, firmware, etc., from GitHub. If after you've covered the basics the results are not what you expect - by all means, please ask this question again.
Speaking of U-boot (bootloader and firmware) - it is independent from kernel (and vice versa, kernel is independent from U-boot). There is a package that claims to support rk3399 SoC in Debian repos, but this installer currently uses the binary blob from mrfixit2001's repo. If you have installed your system before danielt@ updated the installer to use v2.0 of mrfixit2001's blob then you should update your bootloader manually - v2.0 has, among other things, a fix that allows to drop the 'maxcpus' workaround from kernel cmdline.
Actually, I've done apt and have the 5.5 kernel now.
My question regarding the rk3399-pinebook-pro.dtb and the firmware blobs. How far as I understand, they were copied by the installer from the GitHub .
Now they are updated there, but not in my system.
In Debian's repos I see u-boot-rockchip, should I install it?
PBP ISO / Debian Bullseye (unofficial installer)
RE: An unofficial Debian Installer for Pinebook Pro - by wasgurd - 04-05-2020, 11:19 AM
First boot - by JaredT66 - 05-19-2020, 09:49 AM
RE: First boot - by carletes - 05-19-2020, 01:35 PM
  Debian on Pinebook Pro u974615 7 1,305 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,819 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,235 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,326 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,864 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,333 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,149 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,628 09-07-2023, 09:38 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,478 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,548 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
Users browsing this thread: 7 Guest(s)
