An unofficial Debian Installer for Pinebook Pro
(02-20-2020, 05:35 PM)Jeremiah Cornelius Wrote:
(02-20-2020, 04:31 PM)FeMike Wrote: Thank you for sharing this @danielt . I'm new to this but would like to try this out. What would be the basic steps to get this working? Say I want to run this from sdcard, I download the script while booted from stock Debian and run it from terminal, just make sure I select the right device to install to? I saw a few pages back that the installer switches the naming of the devices where sdcard is normally mmcblk0 and pb64 is mmcblk1 it is opposite so I need to pick mmcblk1?
Edit: Disregard, I found the instructions on github. If I have issues I'll try to work it out then post here.
Don't just download the script. There are a number of files - firmware, bootloader, /etc/ configs - that need to be present, relative to your working directory.
$ git clone https://github.com/daniel-thompson/pinebook-pro-debian-installer
This will pull everything you need, into a directory "pinebook-pro-debian-installer" and doesn't take but several seconds on a regular home connection.
cd into the directory and review the README.md for script variables, especially BLKDEV and CRYPT options. Execute as
$ sudo ./install-debian BLKDEV=<var>
Then? Enjoy.
Thank you. So I got the folder and cd'd into it but when I run
sudo ./install-debian CYRPT=n
I get an error, not a git repo. When I downloaded folder I used the clone button on the github website. I'm sure I'm missing something basic, anything stand out? I didn't use the BLKDEV= because in the read me it says it defaults to SD card.
Edit: so I deleted the folder and re downloaded, this time using git clone through terminal and now it's working. Though after all was done, to test I powered down and powered up with sdcard still in place and it booted to the Emmc. I tried one more power cycle to be sure and no go. Though it did write to sdcard as there are multiple partitions that weren't there before. The card's previous state was a working stock Debian from mrfixit so I know it used to work. Should I have prepped the card in any way or does the script handle that?
RE: An unofficial Debian Installer for Pinebook Pro - by FeMike - 02-21-2020, 04:22 AM
First boot - by JaredT66 - 05-19-2020, 09:49 AM
RE: First boot - by carletes - 05-19-2020, 01:35 PM
  Official Debian support moonwalkers 63 53,243 05-16-2024, 11:00 PM
Last Post: rempfer
  Debian on Pinebook Pro u974615 7 1,506 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 2,015 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,308 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,419 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,735 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,468 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,234 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,763 09-07-2023, 09:38 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,622 08-31-2023, 04:20 PM
Last Post: TRS-80
