02-18-2020, 06:30 PM
(02-18-2020, 11:31 AM)xmixahlx Wrote: use the asound.state from manjaro, it is updated. i've edited the installer to do so, see my patch in my sig.It works great ! Thanks !
for ...post install changes:
pull pinebookpro-post-install from manjaro
place asound.state in /var/lib/alsa
sudo alsactl nrestore
reboot (optional...)
configure in pavucontrol
if that doesn't work, alsamixer (f6 for default and es8316)
should work.
while your at it read the PKGBUILD from manjaro and consider the additional changes they have tested.
My next and last problem is the wifi 5ghz stability, do any of you have this kind of problem ? The speed is stuck to 6mbit/s, on the default debian it was working pretty fast. I think it's related to the firmware but I don't understand anything to the broadcom blob firmware
