An unofficial Debian Installer for Pinebook Pro
(01-25-2020, 11:40 AM)xmixahlx Wrote:
(01-24-2020, 04:45 PM)Jeremiah Cornelius Wrote: I just ran an apt upgrade on my Debian with armhf userspace, and it wants to update initramfs after updating cryptsetup-bin and cryptsetup-initramfs.
This hangs, without completing.
From /var/log/apt/history..log :
Setting up initramfs-tools (0.136) ...
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.136) ...
update-initramfs: Generating /boot/initrd.img-5.4.2-2-pinebookpro-arm64
I have to kill this and clear the dpkg lockfiles, but a 'dpkg --configure -a' continues hanging at the same point. Yes, there's plenty of free space on /boot, and it's mounted rw.
Could this be because it's mixing armhf binaries with a arm64 kernel? Seems unlikely - but your own original is all arm64-native, so I wonder...
Are there suggested fixes, if I need a 64-bit cryptsetup-initramfs?
 I don't think so. I was using debian sid armhf for a while to test and didn't have this issue. I recall rebuilding initrd a few times.
I didn't encounter any considerable issue, I was just ready to test arm64 userspace and haven't had any issues there either to change back.
Thanks! This helps.
I did do some deeper troubleshooting this morning. I added the option "set -x" at the top of my /usr/share/initrd-tools/hooks/cryptroot and manually ran update-initrd -u -v for verbose output.
This ensured that update-initrd would show me where it was hanging, and that the hook script would likewise throw status to the console.
So, as I guessed, I'm hanging up in the cryptroot hook. Good hunch.
The lines that lead to the script hanging are here:
+ crypttab_print_entry
+ local DEV MAJ MIN sourcename uuid keyfile
+ resolve_device PARTLABEL=mmcblk2-RootFS
+ local spec=PARTLABEL=mmcblk2-RootFS dev devno maj min
+ resolve_device_spec PARTLABEL=mmcblk2-RootFS
+ blkid -l -t PARTLABEL=mmcblk2-RootFS -o device
I assume the last blkid line is where failure is happening. At this point, console freezes, and is unresponsive to <ctl-c> for breaking, though I can still force the shell to bg the task with a <ctl-z>.
My latest hunch is that there are device name problems? I'm going to try and research - but any help from the forum is really appreciated.
LATE EDIT!
When I run 'sudo blkid' with no arguments, I get a hard hang on the console. I can't even push the task to bg!
Ideas? Suggestions?
THANKS!
Thanks! This helps.
LATE EDIT!
Ideas? Suggestions?
THANKS!
More fun new info. Gparted completely hangs, without rendering. Just a frozen black rectangle, that ties up my display in Wayland.
Some reading online suggests that there's a device not correctly responding to the system function calls in both blkid and parted.
This is introduced behavior - I could formerly run Gparted. Still looking for replies, but I may backup home data, export package list with apt-clone, and re-install.
— Jeremiah Cornelius
RE: An unofficial Debian Installer for Pinebook Pro - by Jeremiah Cornelius - 01-25-2020, 03:08 PM
First boot - by JaredT66 - 05-19-2020, 09:49 AM
RE: First boot - by carletes - 05-19-2020, 01:35 PM
  Debian on Pinebook Pro u974615 7 1,323 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,835 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,243 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,341 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,013 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,345 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,158 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,634 09-07-2023, 09:38 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,495 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,555 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
