An unofficial Debian Installer for Pinebook Pro
#94
(01-15-2020, 09:31 AM)daniel Wrote:
(01-14-2020, 06:50 PM)ThatGeoGuy Wrote: I'm trying to figure out what the rough edges would be, but not having encryption support on a laptop is a pretty big one for me.I assume by default most of the inputs work, and WiFi / Bluetooth is in good shape? If so, it doesn't seem too limited in comparison to default debian, so I'll take your word for it. My plan is to avoid most DEs anyways, and probably stick to awesomewm/sway/i3 anyways. So assuming the basics are working, I don't think my needs are too complex Smile
WiFi works but I'm not using (nor testing) bluetooth at the moment. I have seen some people have had difficulty making it work (check out the mainline kernel thread for clues... IIRC there was something about manually supplying a MAC address).
To be clear I am using a distro built by (a very old version) of the installer as my only OS on the PBP. It's robust and I'm now using PBP to build it's own kernel and bootloaders.
Having said that I'm not spending quite as much time on PBP as I might like... because I have a  PineTime too ;-) .
Alas, it seems bluetooth doesn't work. Relevant thread on the forums: https://forum.pine64.org/showthread.php?...2#pid57292
Has anyone in here had any success with this?
RE: An unofficial Debian Installer for Pinebook Pro - by ThatGeoGuy - 01-18-2020, 05:22 PM
First boot - by JaredT66 - 05-19-2020, 09:49 AM
RE: First boot - by carletes - 05-19-2020, 01:35 PM
  Debian on Pinebook Pro u974615 7 1,342 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,838 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,245 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,344 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,061 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,379 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,176 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,647 09-07-2023, 09:38 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,502 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,577 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
Users browsing this thread: 7 Guest(s)
