how I "fixed" Chromium crashing on accessing settings
(11-28-2019, 10:15 AM)richfm Wrote: I could not sign in and sync my chromium preferences because Chromium crashes when I access "settings". So I installed the snap version of Chromium and now can sync my account and change all preferences. The snap version is a bit slower but usable.
There's a better way to do this. Exit Chromium entirely from the menu so it's not running, open a terminal and run `/usr/lib/chromium-browser/chromium-browser`. This launches the chromium binary directly with no command-line flags and will be slow, but the settings page will work and your settings will persist after this session. Make any settings changes you need then exit chrome and re-start it from the gui as normal, your settings will be in place.
RE: how I "fixed" Chromium crashing on accessing settings - by Arglebargle - 11-28-2019, 12:45 PM
  Ungoogled Chromium on a Pinebook Pro won't run - OpenGL errors? pinemouth 2 5,688 12-09-2021, 02:23 PM
Last Post: pinemouth
Lightbulb Hardware video acceleration in Chromium on Manjaro siemsenit 3 8,315 06-01-2021, 09:51 AM
Last Post: siemsenit
Question Graphical Glitch in Settings sciolus 4 8,123 03-12-2021, 08:23 AM
Last Post: sciolus
  chromium 87: wayland-native maxjrh 0 3,061 11-26-2020, 11:08 AM
Last Post: maxjrh
  Network settings, where to find the config files? hvdkooij 1 4,626 11-20-2020, 02:47 PM
Last Post: xyzzy
  Pinebook pro crashing when put to sleep?? [Manjaro] edward 13 20,946 11-17-2020, 07:17 AM
Last Post: ab1jx
  Chromium Not allowing google login sititahwsi22 1 4,448 11-07-2020, 03:35 PM
Last Post: regivanx
  Saving ALSA settings? Baslow 9 16,633 09-04-2020, 09:05 AM
Last Post: brzegorz
  KWin keeps crashing boudha 5 10,859 09-02-2020, 09:06 AM
Last Post: brad2723
  Focal on Bionic Using Chroot - Chromium / Snapd Issues charlespine 0 2,859 06-03-2020, 06:47 PM
Last Post: charlespine
