Install OS directly to eMMC?
Theoretically yes, the A64 SoC used in the PinePhone has a special bootloader mode called FEL mode, which gives you a special device on the USB port, which in turn allows you to upload code and run it. This can be used to upload a loader that exposes the eMMC as USB mass storage. But I am not sure if that is easier than just using a sdcard to write an image to the eMMC.
Install OS directly to eMMC? - by tahayassen - 11-21-2019, 02:17 PM
RE: Install OS directly to eMMC? - by xalius - 11-21-2019, 02:27 PM
RE: Install OS directly to eMMC? - by bcnaz - 11-21-2019, 02:31 PM
RE: Install OS directly to eMMC? - by tophneal - 11-21-2019, 02:58 PM
RE: Install OS directly to eMMC? - by tahayassen - 11-21-2019, 03:12 PM
RE: Install OS directly to eMMC? - by bcnaz - 11-21-2019, 03:29 PM
RE: Install OS directly to eMMC? - by dukla2000 - 11-22-2019, 02:36 PM
RE: Install OS directly to eMMC? - by Danct12 - 11-21-2019, 10:43 PM
RE: Install OS directly to eMMC? - by bcnaz - 11-22-2019, 03:39 PM
RE: Install OS directly to eMMC? - by explit - 02-28-2020, 08:07 PM
RE: Install OS directly to eMMC? - by Subsentient - 05-15-2020, 09:11 PM
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 25,377 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  changing from bullseye to bookworm to install mmsd-tng jyoung 8 3,104 04-09-2023, 06:08 PM
Last Post: zetabeta
  Install OS Permanently ismkdc 1 1,425 03-20-2023, 01:13 PM
Last Post: fxc
Question PinephonePro can't Flashing to the eMMC ricardo 0 769 08-21-2022, 05:51 AM
Last Post: ricardo
  install packages pamac anbox neithan76 0 741 07-18-2022, 07:13 AM
Last Post: neithan76
  How to replace the home folder on eMMC ragreenburg 2 1,809 03-31-2022, 02:19 PM
Last Post: ragreenburg
  Wipe out eMMC before flashing new OS? zkajdan 15 10,209 11-13-2021, 03:10 AM
Last Post: zetabeta
  Streamlined jmms install amindfv 1 1,722 10-29-2021, 07:04 AM
Last Post: TRS-80
  Anbox: install Google Services sonic 0 1,973 02-07-2021, 04:45 AM
Last Post: sonic
  Emmc drive gone? Flashing with Jump Drive muemmel 2 3,479 11-12-2020, 05:40 PM
Last Post: hiimtye
