DONT INSTALL TO EMMC R77-12371.7.104.g78f88d6 VERSION YET!
(08-06-2020, 05:37 PM)brent.thierens Wrote: If you dd zeros like that, you should be fine.
Alternatively, you can dd the newest uboot version of Manjaro/Debian/... onto the right offsets, and you will be fine as well.
You can find more details and example commands here: https://forum.pine64.org/showthread.php?tid=9062
Hi, Brent, thank you for your follow-up!
I checked the comments.
I understood that just flushing the eMMC would be enough to recover.
I confirmed to disable eMMC by the switch inside, fine, I could boot from SDCard.
I refreshed the eMMC with netbsd and Manjaro respectively, they went fine.
Now I have no concern if I fail to boot from eMMC.
Thank you very much.
Best regards,
Shoichi
RE: DONT INSTALL TO EMMC R77-12371.7.104.g78f88d6 VERSION YET! - by shoichimiyake - 08-07-2020, 11:20 AM
  Cant login to a new install of ChromeOS flatulent_piney 1 3,636 11-10-2020, 01:19 PM
Last Post: flatulent_piney
  Using Crouton to install Arch tophneal 3 7,451 04-27-2020, 06:23 AM
  R77-12371.7.104 ayufan 26 35,084 11-28-2019, 10:20 AM
Last Post: TDC_PBP
