DONT INSTALL TO EMMC R77-12371.7.104.g78f88d6 VERSION YET!
(11-08-2019, 04:26 AM)danielt Wrote:
(11-08-2019, 01:59 AM)erchache2000 Wrote: Some users has experience boot problems with chromium os R77-12371.7.104.g78f88d6
When you burn into emmc you lost ability to boot from sd card.
So you need to extract emmc chip outsite pinebook pro and reburn with a usb emmc dongle.
I think this is the same thing that is seen with the Ubuntu builds (for Ubuntu the workaround is step 6 of https://forum.pine64.org/showthread.php?tid=8119 ).
I don't think you would have to remove the eMMC to restore the ability to boot from SD card. You should be able to use the Chromium debug console (Alt-Ctrl-F2) to copy the mrfixit version of u-boot from an SD card to the eMMC.
Thanks for the info.
I'll propagate this fix. ;P
RE: DONT INSTALL TO EMMC R77-12371.7.104.g78f88d6 VERSION YET! - by erchache2000 - 11-08-2019, 04:33 AM
  Cant login to a new install of ChromeOS flatulent_piney 1 3,633 11-10-2020, 01:19 PM
Last Post: flatulent_piney
  Using Crouton to install Arch tophneal 3 7,446 04-27-2020, 06:23 AM
  R77-12371.7.104 ayufan 26 35,038 11-28-2019, 10:20 AM
Last Post: TDC_PBP
