#92
The issue is observable only with fbturbo - it treats all displays as the default one. If you disable it and run just Panfrost, everything is picked up as expected.
There are a few threads for Raspberry Pi that make adjustment directly to `/etc/X11/xorg.conf.d/99-fbturbo.conf` to manually set the monitor setup. My attempts to use a few of those instructions didn't produce satisfactory results.
On ayufan's and mrfixit's builds I can't see such shenanigans with fbturbo.conf. There should be something else for fbturbo to behave normally with multi-monitor setup that I'm missing.
no output on laptop screen - by belfastraven - 11-08-2019, 08:36 PM
RE: no output on laptop screen - by tsago - 11-09-2019, 04:46 PM
RE: Manjaro - PineBook Pro - Preview Released - by PakoSt - 12-06-2019, 06:47 AM
AUR pakcage typo for notes-tree ? - by dhosh - 02-06-2020, 09:54 AM
Open JRE available for Manjaro? - by dhosh - 02-06-2020, 04:13 PM
  Debian on Pinebook Pro u974615 7 1,043 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 290 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,616 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,764 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 336 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,157 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,233 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,039 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 414 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,249 11-23-2023, 07:37 AM
