#37
(11-12-2019, 09:42 AM)tophneal Wrote: Anyone tried out Wayland yet on Manjaro, yet? I just thought of this (or I would've installed it last night) while reading the linked article mrfritsche posted about Debos. I remember lima being okay, but usable on the Pinebook1080. I'm curious if Panfrost is any better. It would be great to have Night Light available, instead of Redshift/Geoclue2, which I've had nothing but problems with.
Yes I have tried Manjaro with Mainline Kernel, panfrost & wayland over KDE-Plasma, It seems to work fine, Panfrost is very much stable(Partially) though but its getting there. All you have to do is get a working Kde-Plasma Image and remove xf86-video-fbturbo-git then install wayland and switch to wayland on login screen.
Do share your experience with wayland on panfrost.
(11-12-2019, 01:42 PM)Wizzard Wrote: Can somebody confirm if KDE acceleration works?
I think the preview2-kde-plasma is having panfrost by default, And it have seem to work very smooth. Tried playing video on mpv & youtube it worked quite well for me. But you may try it yourself.
(11-12-2019, 07:05 PM)cristobalhdez Wrote: The system crashed after last update.
I'm unable to boot into the system.
The problem seems to be related to Xorg not founding any display.
Please try to get into TTY2 and update again. If you're on KDE then there was a mis-match in kde apps & lib versions. Mostly an upstream issue but Strit have done a great job of downgrading them libs and got it to work.
UPDATE:
Strit have found the issue and have pushed an update to the repo.
Pushed a new update to the
pinebookpro-post-install
 package that fixes it, but if you can't get in to update, you can get to a TTY and run:
sudo rm /usr/share/X11/xorg.conf.d/90-touchpad.conf
Then reboot.
Please try the above and share your feedback.
UPDATE2: New Kernel release should fix the audio crackling, Once it is uploaded to the repo then please update the kernel by running
sudo pacman -S linux-pinebookpro
Manjaro ARM Team.
no output on laptop screen - by belfastraven - 11-08-2019, 08:36 PM
RE: no output on laptop screen - by tsago - 11-09-2019, 04:46 PM
RE: Manjaro - PineBook Pro - Preview Released - by spikerguy - 11-13-2019, 01:37 AM
AUR pakcage typo for notes-tree ? - by dhosh - 02-06-2020, 09:54 AM
Open JRE available for Manjaro? - by dhosh - 02-06-2020, 04:13 PM
  Debian on Pinebook Pro u974615 7 1,390 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 338 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,862 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,810 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 387 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,252 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,356 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,163 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 465 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,396 11-23-2023, 07:37 AM
Users browsing this thread: 7 Guest(s)
