Restore default Debian system
#30
I am a little bit confused, as many others I might have corrupted uboot on the emmc with Debian.
I can boot into the Debian emmc, without sd inserted. It doesn't shutdown completely anymore though, I have to use the power button to power it off.
I can't boot from sd, even if I disable emmc from the switch. I tried to boot Manjaro and the default debian distro from sd without luck.
With the emmc disabled it doesn't turn on at all. With emmc enabled and micro sd inserted it just gets to a black screen.
I also tried to remove and re-attached the ribbon cable to the micro-sd.
Any ideas please?
I ordered the usb to emmc adaptor, but I know it will take a while to come down.
Restore default Debian system - by perceg - 11-06-2019, 11:29 PM
RE: Restore default Debian system - by Blackr0se - 11-07-2019, 02:19 AM
RE: Restore default Debian system - by fire219 - 11-07-2019, 08:29 AM
RE: Restore default Debian system - by bcnaz - 11-07-2019, 08:37 AM
RE: Restore default Debian system - by fire219 - 11-07-2019, 09:47 AM
RE: Restore default Debian system - by perceg - 11-07-2019, 12:10 PM
RE: Restore default Debian system - by perceg - 11-07-2019, 05:27 PM
RE: Restore default Debian system - by evj - 02-06-2020, 11:18 AM
RE: Restore default Debian system - by bcnaz - 11-07-2019, 11:31 PM
RE: Restore default Debian system - by xircledev - 11-08-2019, 12:17 AM
RE: Restore default Debian system - by perceg - 11-08-2019, 05:15 AM
RE: Restore default Debian system - by zaius - 11-08-2019, 06:33 AM
RE: Restore default Debian system - by FeMike - 02-01-2020, 05:39 AM
RE: Restore default Debian system - by uby89 - 02-03-2020, 03:27 AM
RE: Restore default Debian system - by MIchael - 02-03-2020, 06:35 AM
RE: Restore default Debian system - by uby89 - 02-03-2020, 08:13 AM
RE: Restore default Debian system - by MIchael - 02-03-2020, 11:23 AM
RE: Restore default Debian system - by bcnaz - 02-03-2020, 01:04 PM
RE: Restore default Debian system - by uby89 - 02-03-2020, 01:14 PM
RE: Restore default Debian system - by Thovthe - 02-20-2020, 05:28 PM
RE: Restore default Debian system - by PineFan - 02-03-2020, 07:39 PM
RE: Restore default Debian system - by MIchael - 02-04-2020, 07:19 AM
RE: Restore default Debian system - by Thovthe - 02-20-2020, 05:21 PM
RE: Restore default Debian system - by bcnaz - 11-08-2019, 05:36 PM
RE: Restore default Debian system - by bcnaz - 11-08-2019, 12:40 AM
RE: Restore default Debian system - by markh66509 - 12-29-2019, 08:47 AM
RE: Restore default Debian system - by markh66509 - 01-01-2020, 07:59 PM
RE: Restore default Debian system - by bcnaz - 01-01-2020, 10:39 PM
RE: Restore default Debian system - by bcnaz - 01-02-2020, 12:00 AM
RE: Restore default Debian system - by xircledev - 01-06-2020, 08:05 PM
RE: Restore default Debian system - by pmb_nl - 01-26-2020, 03:32 PM
RE: Restore default Debian system - by binholz - 01-28-2020, 05:44 AM
RE: Restore default Debian system - by binholz - 01-28-2020, 11:28 AM
RE: Restore default Debian system - by MIchael - 01-28-2020, 06:06 PM
RE: Restore default Debian system - by bcnaz - 02-03-2020, 01:34 PM
RE: Restore default Debian system - by uby89 - 02-04-2020, 03:21 PM
RE: Restore default Debian system - by weskerfoot - 02-06-2020, 12:24 AM
RE: Restore default Debian system - by weskerfoot - 02-06-2020, 10:01 AM
  Debian on Pinebook Pro u974615 7 1,412 03-31-2024, 10:11 AM
Last Post: u974615
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 385 03-01-2024, 06:46 PM
Last Post: Puckla
  Nethunter default password failed lamlarryyyy 0 388 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  install debian on pbp jsch 7 4,192 11-22-2023, 04:22 PM
Last Post: TRS-80
  Fedora 36 -> 37 upgrade kills system tydeman 0 491 10-28-2023, 09:53 AM
Last Post: tydeman
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,700 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,199 07-15-2023, 02:58 PM
Last Post: u974615
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,311 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,393 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,102 10-19-2022, 03:09 AM
Last Post: alpopa
