Restore default Debian system
#29
(11-08-2019, 06:33 AM)zaius Wrote:
(11-08-2019, 05:15 AM)perceg Wrote:
(11-08-2019, 12:17 AM)xircledev Wrote: I was looking for instructions like this. Everything worked as planned until I tried to reboot. Now the machine is stuck in a loop trying to boot. It never makes it to the boot screen. I can't even run the desktop from the SD now. Any clue as to what I can do?
Thanks.
Same thing here. In order to boot from the SD I needed to switch off the eMMC using the onboard switch. In order to do that you need to open up the bottom cover, look for the white switch to the left of eMMC (numbered 24 on the Pinebook Pro Internal Layout photo at https://wiki.pine64.org/index.php/Pinebo..._Main_Page) and push it sideways into the off position.
Now I can boot from the SD, but obviously still looking for the way to successfully flash default Debian system back to eMMC.
It's a known problem.
https://forum.pine64.org/showthread.php?tid=8162
https://forum.pine64.org/showthread.php?tid=8163
https://forum.pine64.org/showthread.php?tid=8031
You can edit the SD card so that it boots with Debian installed on the eMMC.
You could switch the eMMC off, boot SD, then switch the eMMC back on.  However, opening up a computer that is powered up is generally a bad idea.
You could boot Ubuntu off SD, follow the instructions in the tutorial section to install it to eMMC, then boot Debian off SD, then install it to eMMC.
I too just recently followed the steps from cristobalhdez and it wont boot from emmc. Though I can boot debian from sdcard unlike the others. You mention in your last tip to follow the instructions in the tutorial section to install it to eMMC, where is this? The wiki? I cant find that there, just the link to MrFixit's Debian image. Mind sharing link or steps to do this if it's different from the steps that I followed in post #7? Thank you.
Edit: So I'm not sure what went wrong the first time but I tried it a second time and all is working.
Restore default Debian system - by perceg - 11-06-2019, 11:29 PM
RE: Restore default Debian system - by Blackr0se - 11-07-2019, 02:19 AM
RE: Restore default Debian system - by fire219 - 11-07-2019, 08:29 AM
RE: Restore default Debian system - by bcnaz - 11-07-2019, 08:37 AM
RE: Restore default Debian system - by fire219 - 11-07-2019, 09:47 AM
RE: Restore default Debian system - by perceg - 11-07-2019, 12:10 PM
RE: Restore default Debian system - by perceg - 11-07-2019, 05:27 PM
RE: Restore default Debian system - by evj - 02-06-2020, 11:18 AM
RE: Restore default Debian system - by bcnaz - 11-07-2019, 11:31 PM
RE: Restore default Debian system - by xircledev - 11-08-2019, 12:17 AM
RE: Restore default Debian system - by perceg - 11-08-2019, 05:15 AM
RE: Restore default Debian system - by zaius - 11-08-2019, 06:33 AM
RE: Restore default Debian system - by FeMike - 02-01-2020, 05:39 AM
RE: Restore default Debian system - by uby89 - 02-03-2020, 03:27 AM
RE: Restore default Debian system - by MIchael - 02-03-2020, 06:35 AM
RE: Restore default Debian system - by uby89 - 02-03-2020, 08:13 AM
RE: Restore default Debian system - by MIchael - 02-03-2020, 11:23 AM
RE: Restore default Debian system - by bcnaz - 02-03-2020, 01:04 PM
RE: Restore default Debian system - by uby89 - 02-03-2020, 01:14 PM
RE: Restore default Debian system - by Thovthe - 02-20-2020, 05:28 PM
RE: Restore default Debian system - by PineFan - 02-03-2020, 07:39 PM
RE: Restore default Debian system - by MIchael - 02-04-2020, 07:19 AM
RE: Restore default Debian system - by Thovthe - 02-20-2020, 05:21 PM
RE: Restore default Debian system - by bcnaz - 11-08-2019, 05:36 PM
RE: Restore default Debian system - by bcnaz - 11-08-2019, 12:40 AM
RE: Restore default Debian system - by markh66509 - 12-29-2019, 08:47 AM
RE: Restore default Debian system - by markh66509 - 01-01-2020, 07:59 PM
RE: Restore default Debian system - by bcnaz - 01-01-2020, 10:39 PM
RE: Restore default Debian system - by bcnaz - 01-02-2020, 12:00 AM
RE: Restore default Debian system - by xircledev - 01-06-2020, 08:05 PM
RE: Restore default Debian system - by pmb_nl - 01-26-2020, 03:32 PM
RE: Restore default Debian system - by binholz - 01-28-2020, 05:44 AM
RE: Restore default Debian system - by binholz - 01-28-2020, 11:28 AM
RE: Restore default Debian system - by MIchael - 01-28-2020, 06:06 PM
RE: Restore default Debian system - by bcnaz - 02-03-2020, 01:34 PM
RE: Restore default Debian system - by uby89 - 02-04-2020, 03:21 PM
RE: Restore default Debian system - by weskerfoot - 02-06-2020, 12:24 AM
RE: Restore default Debian system - by weskerfoot - 02-06-2020, 10:01 AM
  Official Debian support moonwalkers 63 52,611 05-16-2024, 11:00 PM
Last Post: rempfer
  Debian on Pinebook Pro u974615 7 1,419 03-31-2024, 10:11 AM
Last Post: u974615
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 387 03-01-2024, 06:46 PM
Last Post: Puckla
  Nethunter default password failed lamlarryyyy 0 389 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  install debian on pbp jsch 7 4,195 11-22-2023, 04:22 PM
Last Post: TRS-80
  Fedora 36 -> 37 upgrade kills system tydeman 0 493 10-28-2023, 09:53 AM
Last Post: tydeman
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,706 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,210 07-15-2023, 02:58 PM
Last Post: u974615
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,313 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,395 12-09-2022, 05:04 AM
Last Post: ndp
