Restore default Debian system
(11-07-2019, 01:23 PM)cristobalhdez Wrote:
(11-07-2019, 12:10 PM)perceg Wrote:
(11-07-2019, 09:47 AM)fire219 Wrote:
(11-07-2019, 08:37 AM)bcnaz Wrote:
(11-07-2019, 08:29 AM)fire219 Wrote: It's pretty simple! Download the latest build of the default Debian image, flash to an SD card, boot from the SD card, and let it flash to the eMMC.
would one use an iso burner to transfer the download to the sd card  ?
No. You need to use a raw image burner tool. Balena Etcher, Win32DiskImager, or normal old "dd" would all do the task.
How does one flash it to the eMMC?
Lets say you used "Etcher" to write the latest debian image to the SD.
Then you booted from the SD.
You will need copy that Debian Image to the SD or Download it again.
Open a new terminal on the same folder than the Debian "zipped" file is located.
Use the next command to "extract" the image file.
  • unxz pinebookpro-debian-desktop-mrfixit-190905.img.xz
That is going to extract the .img file and remove the original file. (this process takes a couple of minutes).
Then to write that image to the eMMC run the next command:
  • sudo dd if=pinebookpro-debian-desktop-mrfixit-190905.img of=/dev/mmcblk1 status=progress
You will be able to see the progress of this process.
At the end, turn off your Pinebook Pro, remove the SD.
Turn on the Pinebook again.
Done.
That's exactly what we were looking for - thank you!!
Restore default Debian system - by perceg - 11-06-2019, 11:29 PM
RE: Restore default Debian system - by Blackr0se - 11-07-2019, 02:19 AM
RE: Restore default Debian system - by fire219 - 11-07-2019, 08:29 AM
RE: Restore default Debian system - by bcnaz - 11-07-2019, 08:37 AM
RE: Restore default Debian system - by fire219 - 11-07-2019, 09:47 AM
RE: Restore default Debian system - by perceg - 11-07-2019, 12:10 PM
RE: Restore default Debian system - by perceg - 11-07-2019, 05:27 PM
RE: Restore default Debian system - by evj - 02-06-2020, 11:18 AM
RE: Restore default Debian system - by bcnaz - 11-07-2019, 11:31 PM
RE: Restore default Debian system - by xircledev - 11-08-2019, 12:17 AM
RE: Restore default Debian system - by perceg - 11-08-2019, 05:15 AM
RE: Restore default Debian system - by zaius - 11-08-2019, 06:33 AM
RE: Restore default Debian system - by FeMike - 02-01-2020, 05:39 AM
RE: Restore default Debian system - by uby89 - 02-03-2020, 03:27 AM
RE: Restore default Debian system - by MIchael - 02-03-2020, 06:35 AM
RE: Restore default Debian system - by uby89 - 02-03-2020, 08:13 AM
RE: Restore default Debian system - by MIchael - 02-03-2020, 11:23 AM
RE: Restore default Debian system - by bcnaz - 02-03-2020, 01:04 PM
RE: Restore default Debian system - by uby89 - 02-03-2020, 01:14 PM
RE: Restore default Debian system - by Thovthe - 02-20-2020, 05:28 PM
RE: Restore default Debian system - by PineFan - 02-03-2020, 07:39 PM
RE: Restore default Debian system - by MIchael - 02-04-2020, 07:19 AM
RE: Restore default Debian system - by Thovthe - 02-20-2020, 05:21 PM
RE: Restore default Debian system - by bcnaz - 11-08-2019, 05:36 PM
RE: Restore default Debian system - by bcnaz - 11-08-2019, 12:40 AM
RE: Restore default Debian system - by markh66509 - 12-29-2019, 08:47 AM
RE: Restore default Debian system - by markh66509 - 01-01-2020, 07:59 PM
RE: Restore default Debian system - by bcnaz - 01-01-2020, 10:39 PM
RE: Restore default Debian system - by bcnaz - 01-02-2020, 12:00 AM
RE: Restore default Debian system - by xircledev - 01-06-2020, 08:05 PM
RE: Restore default Debian system - by pmb_nl - 01-26-2020, 03:32 PM
RE: Restore default Debian system - by binholz - 01-28-2020, 05:44 AM
RE: Restore default Debian system - by binholz - 01-28-2020, 11:28 AM
RE: Restore default Debian system - by MIchael - 01-28-2020, 06:06 PM
RE: Restore default Debian system - by bcnaz - 02-03-2020, 01:34 PM
RE: Restore default Debian system - by uby89 - 02-04-2020, 03:21 PM
RE: Restore default Debian system - by weskerfoot - 02-06-2020, 12:24 AM
RE: Restore default Debian system - by weskerfoot - 02-06-2020, 10:01 AM
  Debian on Pinebook Pro u974615 7 1,200 03-31-2024, 10:11 AM
Last Post: u974615
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 346 03-01-2024, 06:46 PM
Last Post: Puckla
  Nethunter default password failed lamlarryyyy 0 362 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  install debian on pbp jsch 7 4,131 11-22-2023, 04:22 PM
Last Post: TRS-80
  Fedora 36 -> 37 upgrade kills system tydeman 0 464 10-28-2023, 09:53 AM
Last Post: tydeman
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,583 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,123 07-15-2023, 02:58 PM
Last Post: u974615
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,294 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,365 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,068 10-19-2022, 03:09 AM
Last Post: alpopa
