Pinebook Pro won't turn on
#60
(05-18-2020, 04:54 PM)wdt Wrote: >cd emmc/boot
I don't know where the emmc will be mounted, replace "emmc" as appropriate
the last line from "mount" should be it, after you have mounted it, of course
Use whatever file manager you use to mount it (whichever partition of emmc)
The md5sum on the download link is for the whole gz, everything
These md5sums are for individual parts
>the emmc can not be mounted.
Not the whole block device, no, but the individual partitions should be able to be (mounted)
--edit-- this from PBP, booted manjaro, looking at emmc, mrfixit, updated (emmc at /run/media/d/BOOT, that partition labeled "BOOT")
NOTE there is no standard for block numbers, mrfixit differs from manjaro, look at lsblk, / will be SD card (when booted SD)
Sorry I didn't reply to this post earlier with some kind of acknowledgment of your help, wdt. I did not understand at first and I have been trying to grasp your meaning. I think I get it now. You simply wanted to compare the checksums for the SD card and the emmc. They should have been the same for the SD card and the emmc if the install had worked correctly, as I had already tried to write the same os on the SD card to the emmc. No? I should have got this sooner.
Anyway, I think I've tried everything now. The emmc adapter will arrive in the post some day and then I'll rewrite the disk.
I noticed that the mrfixit debian image I had downloaded was an earlier one than the one on the github page, but the wiki page has already been changed and it now links to the latest download image.
Pinebook Pro won't turn on - by codebreaker - 10-31-2019, 01:52 PM
RE: Pinebook Pro won't turn on - by Wizzard - 10-31-2019, 02:06 PM
RE: Pinebook Pro won't turn on - by codebreaker - 10-31-2019, 02:08 PM
RE: Pinebook Pro won't turn on - by hmuller - 10-31-2019, 08:17 PM
RE: Pinebook Pro won't turn on - by GLSRacer - 11-01-2019, 06:34 PM
RE: Pinebook Pro won't turn on - by bebop_man - 11-01-2019, 06:43 PM
RE: Pinebook Pro won't turn on - by GLSRacer - 11-01-2019, 06:51 PM
RE: Pinebook Pro won't turn on - by bebop_man - 11-01-2019, 07:01 PM
RE: Pinebook Pro won't turn on - by GLSRacer - 11-01-2019, 08:09 PM
RE: Pinebook Pro won't turn on - by bebop_man - 11-01-2019, 08:43 PM
RE: Pinebook Pro won't turn on - by hsm89cheu - 11-01-2019, 11:12 PM
RE: Pinebook Pro won't turn on - by bebop_man - 11-02-2019, 06:58 AM
RE: Pinebook Pro won't turn on - by TAAPAye - 11-02-2019, 12:53 PM
RE: Pinebook Pro won't turn on - by bebop_man - 11-02-2019, 05:34 PM
RE: Pinebook Pro won't turn on - by hsm89cheu - 11-04-2019, 12:46 PM
RE: Pinebook Pro won't turn on - by S265 - 01-26-2020, 12:57 AM
RE: Pinebook Pro won't turn on - by tllim - 05-30-2020, 03:58 PM
RE: Pinebook Pro won't turn on - by Luke - 11-02-2019, 05:57 PM
RE: Pinebook Pro won't turn on - by Arwen - 11-02-2019, 07:42 PM
RE: Pinebook Pro won't turn on - by Baius - 11-03-2019, 09:18 PM
RE: Pinebook Pro won't turn on - by Baius - 11-04-2019, 09:32 PM
RE: Pinebook Pro won't turn on - by GLSRacer - 11-04-2019, 12:54 PM
RE: Pinebook Pro won't turn on - by Baius - 11-04-2019, 09:39 PM
RE: Pinebook Pro won't turn on - by JulienSchott - 11-09-2019, 05:04 AM
RE: Pinebook Pro won't turn on - by JulienSchott - 11-10-2019, 06:08 AM
RE: Pinebook Pro won't turn on - by Gerhard - 01-02-2020, 10:21 AM
RE: Pinebook Pro won't turn on - by tophneal - 01-02-2020, 10:37 AM
RE: Pinebook Pro won't turn on - by Gerhard - 01-03-2020, 02:04 PM
RE: Pinebook Pro won't turn on - by tophneal - 01-03-2020, 02:06 PM
RE: Pinebook Pro won't turn on - by bkepley - 01-20-2020, 06:04 PM
RE: Pinebook Pro won't turn on - by bkepley - 01-21-2020, 07:34 AM
RE: Pinebook Pro won't turn on - by danielt - 01-21-2020, 11:15 AM
RE: Pinebook Pro won't turn on - by bcnaz - 01-27-2020, 01:02 AM
RE: Pinebook Pro won't turn on - by xmixahlx - 01-27-2020, 02:03 AM
RE: Pinebook Pro won't turn on - by tllim - 01-29-2020, 09:38 PM
RE: Pinebook Pro won't turn on - by Frobozz - 02-18-2020, 08:43 PM
RE: Pinebook Pro won't turn on - by gimy16 - 05-03-2020, 03:19 PM
RE: Pinebook Pro won't turn on - by leibide - 05-08-2020, 12:16 PM
RE: Pinebook Pro won't turn on - by wdt - 05-04-2020, 11:11 AM
RE: Pinebook Pro won't turn on - by gimy16 - 05-05-2020, 02:13 AM
RE: Pinebook Pro won't turn on - by wdt - 05-05-2020, 08:30 PM
RE: Pinebook Pro won't turn on - by wdt - 05-08-2020, 02:58 PM
RE: Pinebook Pro won't turn on - by leibide - 05-09-2020, 01:16 PM
RE: Pinebook Pro won't turn on - by wdt - 05-09-2020, 08:31 PM
RE: Pinebook Pro won't turn on - by leibide - 05-10-2020, 10:06 AM
RE: Pinebook Pro won't turn on - by wdt - 05-10-2020, 03:08 PM
RE: Pinebook Pro won't turn on - by leibide - 05-13-2020, 10:16 AM
RE: Pinebook Pro won't turn on - by wdt - 05-13-2020, 06:05 PM
RE: Pinebook Pro won't turn on - by leibide - 05-14-2020, 02:19 PM
RE: Pinebook Pro won't turn on - by wdt - 05-14-2020, 03:57 PM
RE: Pinebook Pro won't turn on - by leibide - 05-17-2020, 12:49 PM
RE: Pinebook Pro won't turn on - by wdt - 05-17-2020, 05:07 PM
RE: Pinebook Pro won't turn on - by leibide - 05-18-2020, 04:16 AM
RE: Pinebook Pro won't turn on - by wdt - 05-18-2020, 08:11 AM
RE: Pinebook Pro won't turn on - by leibide - 05-18-2020, 09:13 AM
RE: Pinebook Pro won't turn on - by wdt - 05-18-2020, 10:44 AM
RE: Pinebook Pro won't turn on - by leibide - 05-18-2020, 12:05 PM
RE: Pinebook Pro won't turn on - by wdt - 05-18-2020, 04:54 PM
RE: Pinebook Pro won't turn on - by leibide - 06-12-2020, 01:03 PM
RE: Pinebook Pro won't turn on - by leibide - 06-15-2020, 11:45 AM
RE: Pinebook Pro won't turn on - by iav - 09-21-2020, 01:16 PM
RE: Pinebook Pro won't turn on - by cefre00 - 10-27-2020, 08:27 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 669 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 369 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 312 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 655 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,158 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,346 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,102 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,509 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 137,723 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,937 10-21-2022, 07:57 AM
Last Post: dachalife
