Pinebook Pro won't turn on
#46
"You are connected to internet???"
wdt, your suspicion has proved correct - I forgot to even connect to the internet. Doh!
"I assume you have another computer?"
Yes, an X86 desktop, though I've mostly been trying from a second Pinebkpro that I got my father.
I've followed your instructions. Here's what that looks like in the terminal window:
rock@Debian-Desktop:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 931.5G 0 disk
`-sda1 8:1 0 931.5G 0 part /media/rock/Disque Dur
mmcblk1 179:0 0 58.2G 0 disk
`-mmcblk1p2 179:2 0 58G 0 part /media/rock/ROOT_MNJRO
mmcblk1boot0 179:32 0 4M 1 disk
mmcblk1boot1 179:64 0 4M 1 disk
mmcblk1rpmb 179:96 0 16M 0 disk
mmcblk0 179:128 0 59.5G 0 disk
|-mmcblk0p1 179:129 0 64M 0 part /boot
`-mmcblk0p2 179:130 0 59.4G 0 part /
rock@Debian-Desktop:~$ mount|grep mmc
/dev/mmcblk0p2 on / type ext4 (rw,relatime,data=ordered)
/dev/mmcblk0p1 on /boot type vfat (ro,relatime,fmask=0022,dmask=0022,codepage=936,iocharset=utf8,shortname=mixed,errors=remount-ro)
/dev/mmcblk1p2 on /media/rock/ROOT_MNJRO type ext4 (rw,nosuid,nodev,relatime,data=ordered,uhelper=udisks2)
rock@Debian-Desktop:~$ cd Downloads
rock@Debian-Desktop:~/Downloads$ ls
mmcblk0 pinebookpro-debian-desktop-mrfixit-191123.img.xz
rock@Debian-Desktop:~/Downloads$ xzcat pinebookpro-debian-desktop-mrfixit-191123.img.xz|dd of=mmcblk0 bs=1M
0+634460 records in
0+634460 records out
5377097728 bytes (5.4 GB, 5.0 GiB) copied, 240.572 s, 22.4 MB/s
rock@Debian-Desktop:~/Downloads$ sync
rock@Debian-Desktop:~/Downloads$ uname -r
4.4.202
Then shutdown. Removed SD. Red LED light when I turned on, but nothing more. I should mention, Debian on this SD card did not shut down properly. It always gives a dark screen with a green LED. A white underscore flashes in the top left corner of screen for a few seconds also. With my new confidence in dd commands, I tried Bionic LXDE using the same instructions as before.
So from Downloads in Debian on SD card:
bionic-lxde-pinebookpro-0.9.14-1159-armhf.img.xz
mmcblk0
rock@Debian-Desktop:~/Downloads$ ^C
rock@Debian-Desktop:~/Downloads$ xzcat bionic-lxde-pinebookpro-0.9.14-1159-armhf.img.xz|dd of=mmcblk0 bs=1M
0+450692 records in
0+450692 records out
3757047808 bytes (3.8 GB, 3.5 GiB) copied, 149.734 s, 25.1 MB/s
rock@Debian-Desktop:~/Downloads$ cd
rock@Debian-Desktop:~$ uname-r
bash: uname-r: command not found
Linux
As with my attempt with Bionic LXDE on SD card, computer gives red then green light on turn on, then nothing more.
I'm making heavy work of this, but I feel I'm getting there. I'm happy to pull out the emmc and dd directly to that from another computer if necessary (I have an SD/emmc adapter for use on USB type A port).
Pinebook Pro won't turn on - by codebreaker - 10-31-2019, 01:52 PM
RE: Pinebook Pro won't turn on - by Wizzard - 10-31-2019, 02:06 PM
RE: Pinebook Pro won't turn on - by codebreaker - 10-31-2019, 02:08 PM
RE: Pinebook Pro won't turn on - by hmuller - 10-31-2019, 08:17 PM
RE: Pinebook Pro won't turn on - by GLSRacer - 11-01-2019, 06:34 PM
RE: Pinebook Pro won't turn on - by bebop_man - 11-01-2019, 06:43 PM
RE: Pinebook Pro won't turn on - by GLSRacer - 11-01-2019, 06:51 PM
RE: Pinebook Pro won't turn on - by bebop_man - 11-01-2019, 07:01 PM
RE: Pinebook Pro won't turn on - by GLSRacer - 11-01-2019, 08:09 PM
RE: Pinebook Pro won't turn on - by bebop_man - 11-01-2019, 08:43 PM
RE: Pinebook Pro won't turn on - by hsm89cheu - 11-01-2019, 11:12 PM
RE: Pinebook Pro won't turn on - by bebop_man - 11-02-2019, 06:58 AM
RE: Pinebook Pro won't turn on - by TAAPAye - 11-02-2019, 12:53 PM
RE: Pinebook Pro won't turn on - by bebop_man - 11-02-2019, 05:34 PM
RE: Pinebook Pro won't turn on - by hsm89cheu - 11-04-2019, 12:46 PM
RE: Pinebook Pro won't turn on - by S265 - 01-26-2020, 12:57 AM
RE: Pinebook Pro won't turn on - by tllim - 05-30-2020, 03:58 PM
RE: Pinebook Pro won't turn on - by Luke - 11-02-2019, 05:57 PM
RE: Pinebook Pro won't turn on - by Arwen - 11-02-2019, 07:42 PM
RE: Pinebook Pro won't turn on - by Baius - 11-03-2019, 09:18 PM
RE: Pinebook Pro won't turn on - by Baius - 11-04-2019, 09:32 PM
RE: Pinebook Pro won't turn on - by GLSRacer - 11-04-2019, 12:54 PM
RE: Pinebook Pro won't turn on - by Baius - 11-04-2019, 09:39 PM
RE: Pinebook Pro won't turn on - by JulienSchott - 11-09-2019, 05:04 AM
RE: Pinebook Pro won't turn on - by JulienSchott - 11-10-2019, 06:08 AM
RE: Pinebook Pro won't turn on - by Gerhard - 01-02-2020, 10:21 AM
RE: Pinebook Pro won't turn on - by tophneal - 01-02-2020, 10:37 AM
RE: Pinebook Pro won't turn on - by Gerhard - 01-03-2020, 02:04 PM
RE: Pinebook Pro won't turn on - by tophneal - 01-03-2020, 02:06 PM
RE: Pinebook Pro won't turn on - by bkepley - 01-20-2020, 06:04 PM
RE: Pinebook Pro won't turn on - by bkepley - 01-21-2020, 07:34 AM
RE: Pinebook Pro won't turn on - by danielt - 01-21-2020, 11:15 AM
RE: Pinebook Pro won't turn on - by bcnaz - 01-27-2020, 01:02 AM
RE: Pinebook Pro won't turn on - by xmixahlx - 01-27-2020, 02:03 AM
RE: Pinebook Pro won't turn on - by tllim - 01-29-2020, 09:38 PM
RE: Pinebook Pro won't turn on - by Frobozz - 02-18-2020, 08:43 PM
RE: Pinebook Pro won't turn on - by gimy16 - 05-03-2020, 03:19 PM
RE: Pinebook Pro won't turn on - by leibide - 05-08-2020, 12:16 PM
RE: Pinebook Pro won't turn on - by wdt - 05-04-2020, 11:11 AM
RE: Pinebook Pro won't turn on - by gimy16 - 05-05-2020, 02:13 AM
RE: Pinebook Pro won't turn on - by wdt - 05-05-2020, 08:30 PM
RE: Pinebook Pro won't turn on - by wdt - 05-08-2020, 02:58 PM
RE: Pinebook Pro won't turn on - by leibide - 05-09-2020, 01:16 PM
RE: Pinebook Pro won't turn on - by wdt - 05-09-2020, 08:31 PM
RE: Pinebook Pro won't turn on - by leibide - 05-10-2020, 10:06 AM
RE: Pinebook Pro won't turn on - by wdt - 05-10-2020, 03:08 PM
RE: Pinebook Pro won't turn on - by leibide - 05-13-2020, 10:16 AM
RE: Pinebook Pro won't turn on - by wdt - 05-13-2020, 06:05 PM
RE: Pinebook Pro won't turn on - by leibide - 05-14-2020, 02:19 PM
RE: Pinebook Pro won't turn on - by wdt - 05-14-2020, 03:57 PM
RE: Pinebook Pro won't turn on - by leibide - 05-17-2020, 12:49 PM
RE: Pinebook Pro won't turn on - by wdt - 05-17-2020, 05:07 PM
RE: Pinebook Pro won't turn on - by leibide - 05-18-2020, 04:16 AM
RE: Pinebook Pro won't turn on - by wdt - 05-18-2020, 08:11 AM
RE: Pinebook Pro won't turn on - by leibide - 05-18-2020, 09:13 AM
RE: Pinebook Pro won't turn on - by wdt - 05-18-2020, 10:44 AM
RE: Pinebook Pro won't turn on - by leibide - 05-18-2020, 12:05 PM
RE: Pinebook Pro won't turn on - by wdt - 05-18-2020, 04:54 PM
RE: Pinebook Pro won't turn on - by leibide - 06-12-2020, 01:03 PM
RE: Pinebook Pro won't turn on - by leibide - 06-15-2020, 11:45 AM
RE: Pinebook Pro won't turn on - by iav - 09-21-2020, 01:16 PM
RE: Pinebook Pro won't turn on - by cefre00 - 10-27-2020, 08:27 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 751 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 380 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 325 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 662 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,170 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,902 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,149 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,581 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 138,244 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,970 10-21-2022, 07:57 AM
Last Post: dachalife
