Pinebook Pro won't turn on
#45
There is NO install for mrfixit's debian, the install is a dd (to emmc)
To install to SD, use etcher, I assume you have another computer?
From this other computer, using etcher, unless you already have done it
Then boot it, set up user, don't bother upgrading at this point
Copy pinebookpro-debian-desktop-mrfixit-191123.img.xz (mrfixit debian) to Downloads
on SD card (/home/$USER/Downloads ($USER is whatever your login name is)
Then boot with SD inserted, lsblk and mount|grep mmc will tell which mmcblk is which
(/ is on SD card, partition 2, p2,,,,, boot on same card,, p1, emmc is obviously other mmcblk
this is if the SD card boots OK, first boot will ask for a user and password other than rock64 IIRR)
Then run commands above, will install mrfixit as OOTB (out of the box), just as
when you first got PBP (on emmc)
One way to be sure you have booted mrfixit is run uname -r ,,,, will either be 4.4.210 or 4.4.213
--edit--
> the Debian on the SD card fails to run a software upgrade
You are connected to internet??? ping google.com succeeds??
It is a manual process for debian, apt-get update, apt-get upgrade,, mrfixit's upgrade is a bit "iffy",,try again
Understand, there are 2 different upgrades, mrfixit and debian, mrfixit is the icon one
Pinebook Pro won't turn on - by codebreaker - 10-31-2019, 01:52 PM
RE: Pinebook Pro won't turn on - by Wizzard - 10-31-2019, 02:06 PM
RE: Pinebook Pro won't turn on - by codebreaker - 10-31-2019, 02:08 PM
RE: Pinebook Pro won't turn on - by hmuller - 10-31-2019, 08:17 PM
RE: Pinebook Pro won't turn on - by GLSRacer - 11-01-2019, 06:34 PM
RE: Pinebook Pro won't turn on - by bebop_man - 11-01-2019, 06:43 PM
RE: Pinebook Pro won't turn on - by GLSRacer - 11-01-2019, 06:51 PM
RE: Pinebook Pro won't turn on - by bebop_man - 11-01-2019, 07:01 PM
RE: Pinebook Pro won't turn on - by GLSRacer - 11-01-2019, 08:09 PM
RE: Pinebook Pro won't turn on - by bebop_man - 11-01-2019, 08:43 PM
RE: Pinebook Pro won't turn on - by hsm89cheu - 11-01-2019, 11:12 PM
RE: Pinebook Pro won't turn on - by bebop_man - 11-02-2019, 06:58 AM
RE: Pinebook Pro won't turn on - by TAAPAye - 11-02-2019, 12:53 PM
RE: Pinebook Pro won't turn on - by bebop_man - 11-02-2019, 05:34 PM
RE: Pinebook Pro won't turn on - by hsm89cheu - 11-04-2019, 12:46 PM
RE: Pinebook Pro won't turn on - by S265 - 01-26-2020, 12:57 AM
RE: Pinebook Pro won't turn on - by tllim - 05-30-2020, 03:58 PM
RE: Pinebook Pro won't turn on - by Luke - 11-02-2019, 05:57 PM
RE: Pinebook Pro won't turn on - by Arwen - 11-02-2019, 07:42 PM
RE: Pinebook Pro won't turn on - by Baius - 11-03-2019, 09:18 PM
RE: Pinebook Pro won't turn on - by Baius - 11-04-2019, 09:32 PM
RE: Pinebook Pro won't turn on - by GLSRacer - 11-04-2019, 12:54 PM
RE: Pinebook Pro won't turn on - by Baius - 11-04-2019, 09:39 PM
RE: Pinebook Pro won't turn on - by JulienSchott - 11-09-2019, 05:04 AM
RE: Pinebook Pro won't turn on - by JulienSchott - 11-10-2019, 06:08 AM
RE: Pinebook Pro won't turn on - by Gerhard - 01-02-2020, 10:21 AM
RE: Pinebook Pro won't turn on - by tophneal - 01-02-2020, 10:37 AM
RE: Pinebook Pro won't turn on - by Gerhard - 01-03-2020, 02:04 PM
RE: Pinebook Pro won't turn on - by tophneal - 01-03-2020, 02:06 PM
RE: Pinebook Pro won't turn on - by bkepley - 01-20-2020, 06:04 PM
RE: Pinebook Pro won't turn on - by bkepley - 01-21-2020, 07:34 AM
RE: Pinebook Pro won't turn on - by danielt - 01-21-2020, 11:15 AM
RE: Pinebook Pro won't turn on - by bcnaz - 01-27-2020, 01:02 AM
RE: Pinebook Pro won't turn on - by xmixahlx - 01-27-2020, 02:03 AM
RE: Pinebook Pro won't turn on - by tllim - 01-29-2020, 09:38 PM
RE: Pinebook Pro won't turn on - by Frobozz - 02-18-2020, 08:43 PM
RE: Pinebook Pro won't turn on - by gimy16 - 05-03-2020, 03:19 PM
RE: Pinebook Pro won't turn on - by leibide - 05-08-2020, 12:16 PM
RE: Pinebook Pro won't turn on - by wdt - 05-04-2020, 11:11 AM
RE: Pinebook Pro won't turn on - by gimy16 - 05-05-2020, 02:13 AM
RE: Pinebook Pro won't turn on - by wdt - 05-05-2020, 08:30 PM
RE: Pinebook Pro won't turn on - by wdt - 05-08-2020, 02:58 PM
RE: Pinebook Pro won't turn on - by leibide - 05-09-2020, 01:16 PM
RE: Pinebook Pro won't turn on - by wdt - 05-09-2020, 08:31 PM
RE: Pinebook Pro won't turn on - by leibide - 05-10-2020, 10:06 AM
RE: Pinebook Pro won't turn on - by wdt - 05-10-2020, 03:08 PM
RE: Pinebook Pro won't turn on - by leibide - 05-13-2020, 10:16 AM
RE: Pinebook Pro won't turn on - by wdt - 05-13-2020, 06:05 PM
RE: Pinebook Pro won't turn on - by leibide - 05-14-2020, 02:19 PM
RE: Pinebook Pro won't turn on - by wdt - 05-14-2020, 03:57 PM
RE: Pinebook Pro won't turn on - by leibide - 05-17-2020, 12:49 PM
RE: Pinebook Pro won't turn on - by wdt - 05-17-2020, 05:07 PM
RE: Pinebook Pro won't turn on - by leibide - 05-18-2020, 04:16 AM
RE: Pinebook Pro won't turn on - by wdt - 05-18-2020, 08:11 AM
RE: Pinebook Pro won't turn on - by leibide - 05-18-2020, 09:13 AM
RE: Pinebook Pro won't turn on - by wdt - 05-18-2020, 10:44 AM
RE: Pinebook Pro won't turn on - by leibide - 05-18-2020, 12:05 PM
RE: Pinebook Pro won't turn on - by wdt - 05-18-2020, 04:54 PM
RE: Pinebook Pro won't turn on - by leibide - 06-12-2020, 01:03 PM
RE: Pinebook Pro won't turn on - by leibide - 06-15-2020, 11:45 AM
RE: Pinebook Pro won't turn on - by iav - 09-21-2020, 01:16 PM
RE: Pinebook Pro won't turn on - by cefre00 - 10-27-2020, 08:27 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 737 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 378 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 325 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 661 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,165 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,736 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,142 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,565 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 138,117 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,968 10-21-2022, 07:57 AM
Last Post: dachalife
