EMMc to usb adaoter
(10-04-2019, 03:43 PM)bcnaz Wrote: Is the usb to EMMc adapter  that sells at the Pine store the correct one to pre-load the EMMc module for use in the Pine Book Pro  ?
             What are the different EMMc module speeds   r/w   ?
             Are those EMMc's for sale at the Pine store fast "in their class"   ?
                     ( Im sure someone will say they are slow compared to all the SSD's, but I know that)
I purchased one of these USB to eMMC adapters with a 32GB eMMC module. My desktop reads the eMMC module attached to the adapter. That gives me the ability to burn an image to the eMMC module and then to modify that image if necessary, from my desktop. Does that answer your first question?
For rated eMMC module R/W speeds, see page 17:
http://files.pine64.org/doc/datasheet/pi...0v1.13.pdf
Are they fast in their class?
Yes, are they the fastest? No. You can purchase the SanDisk 32GB eMMC from Pine64 (sequential R/W speeds 150/290 MBs) for $25 USD. Or you can purchase the Samsung (odroid-xu4) 32GB eMMC on Amazon (sequential R/W speeds 200/330 MBs) for $42 USD.
EMMc to usb adaoter - by bcnaz - 10-04-2019, 03:43 PM
RE: EMMc to usb adaoter - by hmuller - 11-05-2019, 09:29 PM
  256GB EMMC! sallyhaj 1 833 10-03-2023, 07:42 AM
  eMMC failed Dendrocalamus64 9 7,095 11-12-2021, 11:08 AM
Last Post: Dendrocalamus64
  Upgrade eMMC card - boot problems alpopa 0 2,307 09-16-2020, 12:31 PM
Last Post: alpopa
  128GB eMMC support dgkPBP 7 8,848 09-08-2020, 07:36 AM
  Manjaro 20.06 requires multiple boots from eMMC to launch successfully on PBP Spectre 0 2,239 07-09-2020, 06:12 PM
Last Post: Spectre
  eMMC to USB adapter "very" slow at reading data talpa 3 5,290 07-08-2020, 08:55 AM
Last Post: talpa
  Internal installation of additional eMMC Besouro 7 8,581 06-06-2020, 09:33 PM
Last Post: xmixahlx
  Boot problems with new 128GB eMMC module Kareema 1 3,329 05-31-2020, 10:36 AM
Last Post: Kareema
Star Could you please add 128GB eMMC as a build option for this preorder? Dendrocalamus64 3 4,533 03-23-2020, 04:54 AM
Last Post: xmixahlx
  Emmc to MicroSD adapter won't fit in recessed slot of pbp sunjam 3 4,425 03-04-2020, 01:20 PM
Last Post: zaius
