Are Pinebook images compatible with Pine64+?
(09-18-2019, 06:33 AM)tophneal Wrote:
(09-18-2019, 06:21 AM)starcrescent Wrote:
(09-17-2019, 12:24 PM)tophneal Wrote:
(09-17-2019, 11:13 AM)starcrescent Wrote:
(09-17-2019, 06:59 AM)tophneal Wrote: Not straight from the A64+ download page. Likely the linux images will need to include the additional hardware of the Pinebook. Did you already try one of the Pinebook linux images (Original, 1080P)? Try one of these Manjaro images for the Pinebook.
Yes already tried Manjaro LXQT Pinebook built on Pine64+ no screen response at all
What version? Manjaro dropped LXQT for the PB with the release of 19.06 or .08.
Could you elaborate when you say "built on Pine64+"? Manjaro has seperate images for A64+ and Pinebook. If you wanted to use LXQT, I suggest the XFCE replacement image.
Sorry it was this image https://osdn.net/projects/manjaro-arm/st...fce/19.08/
I tried it on Pine64+ because there is no specific manjaro image for Pine64+
Is there a way to modify it?
Ah! I misunderstood your goal/question.
Here's an option you might try, a user here on Pine has submitted their own build for the 64+.
This forum thread might also be of help. Another user asks about modifying an image for the 64+.
If you don't have an account on the Manjaro Arm boards, I suggest it. Strit and the other devs are very responsive and helpful.
Thanks for the pointer. Anything about Android 8.1 on Pine64+?
(09-17-2019, 11:13 AM)starcrescent Wrote: Yes already tried Manjaro LXQT Pinebook built on Pine64+ no screen response at all
I just realized there is no Android 8 for Pine64+. Nevermind.
RE: Are Pinebook images compatible with Pine64+? - by starcrescent - 09-18-2019, 06:41 AM
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 2 864 05-26-2025, 11:01 AM
  DietPi OS for Pinebook MichaIng 3 8,972 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 79,795 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 2,372 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 1,738 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 8,241 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 4,452 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 5,876 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 6,843 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 4,871 01-20-2021, 11:18 AM
