Charging via USB-C Port
I was going to ask if the MacBook Pro charger (61W) would work.
But then I researched and Apple says: 'The Apple 61W USB-C Power Adapter first declares it supports 12 watts (5 volts @ 2.4 amps)'
For reference, stock Pinebook Pro barrel pin uses 5volts at 0.5amp.
So the MacBook charger should work safely - and may allow faster charging as more amps - I'm testing it now.
Stock barrel pin charger is AGONISINGLY slow to charge the device - especially when watching HD video - it went from 30% to 28% for me after an hour of watching video, meaning it wasn't getting enough amps to charge properly.
Sorry for bumping an old thread, just thought my findings may help someone.
Charging via USB-C Port - by tyha - 08-22-2019, 11:51 PM
RE: Charging via USB-C Port - by kaylios - 08-23-2019, 02:56 AM
RE: Charging via USB-C Port - by Luke - 08-23-2019, 08:07 AM
RE: Charging via USB-C Port - by kaylios - 08-23-2019, 10:17 AM
RE: Charging via USB-C Port - by hdk - 11-26-2019, 07:54 AM
RE: Charging via USB-C Port - by Eggmonkey - 04-10-2020, 12:04 PM
RE: Charging via USB-C Port - by Eggmonkey - 04-10-2020, 01:25 PM
RE: Charging via USB-C Port - by Arwen - 04-11-2020, 04:20 PM
RE: Charging via USB-C Port - by MIchael - 04-11-2020, 07:38 PM
RE: Charging via USB-C Port - by iscmob - 07-19-2020, 08:30 PM
RE: Charging via USB-C Port - by MtnSk8 - 07-20-2020, 01:50 PM
RE: Charging via USB-C Port - by JaceAlvejetti - 07-20-2020, 06:25 PM
RE: Charging via USB-C Port - by iscmob - 07-21-2020, 08:28 PM
RE: Charging via USB-C Port - by JasonG-FR - 07-22-2020, 03:15 AM
RE: Charging via USB-C Port - by iscmob - 07-22-2020, 08:15 PM
Photo P{inebook Pro not charging Ome Ko 6 2,016 11-09-2023, 03:29 PM
Last Post: tomekdev
  Pine Book Pro Charging Problems balin 7 6,941 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  How are people finding the type-A USB 3.0 port? chris88233 1 1,011 10-01-2022, 01:04 AM
Last Post: LivingLinux
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,541 02-22-2022, 11:20 AM
  Fried the charger port and USB leapylee 1 1,611 01-12-2022, 03:32 AM
Last Post: Danct12
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 4,325 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  HArdware issues while charging user18130814200115 2 2,842 05-01-2021, 04:13 AM
Last Post: gabeeg
  Serial port cable bsammon 17 24,605 03-04-2021, 10:00 AM
Last Post: mattpenn
  PineBookPro does not charging floppy_rofling 0 1,655 02-03-2021, 05:29 AM
Last Post: floppy_rofling
  Screen flicker with USB-C charging bchenlee609 5 5,894 01-25-2021, 08:48 PM
Last Post: bchenlee609
