rockpro 64 does not boot up automatically after software reboot
(10-23-2019, 01:34 PM)Nikolay_Po Wrote: Thank you for explanation. Do you use the same type flash memory in every case? May be the root of the problem is in flash media stability?
I used single ROCKpro64 for several month without a UPS. And after tens of sudden shutdowns there was none startup failures. Both "Transcend microSDXC 300S Class 10 Uhs-i U3 A1 V30 128GB" card and 16GB Pine64 flash module was able to restart correctly after any shutdowns, including power failures.
  1. What storage media are connected to your boards at the moment of power failure and restart?
  2. Was there any Android OS written to the media before? How could it start?
  3. Was Android overwritten by different OS before failure?
The startup of different OS is an interesting fact. If unwanted OS was not kept on the media intentionally it's start may be an evidence of major flash memory controller failure.
It is well known that newer data are always written to the blocks of flash cells which was worn less. So until the amount of data written is less than media capacity the elder information will still persist on the media.
In case of sudden power failure the flash controller may corrupt the data written last. But previously written data, even being overwritten, may return because of controller database intrinsic backup restoration.
Try to perform periodic "fstrim -a". The trimming itself may initiate flash media controller database update. And in case of sudden power loss it may return to more fresh backup than without of trimming.
Thanks for the elaboration. It gave me some clarifications.
For your querries -
Yes
eMMC 16GB from pine iteself (FORESEE NCEMAM8B-16G Z1S18061467571826).
No only Ubuntu18.04 LXDE image have been used from initial. I asked the same issue with pine support guys they suggested me to test the same with Android 7.2 OS. And it booted don't know how.
No, Android was not even in the picture before.
One more point, i tested the same board with Armbian image and it also worked but not with the Ubuntu based eMMC. The interesting point is if i reflashed the same eMMC with fresh Ubuntu image then it works. So clearly OS corruption but few devices even don't boot with any of the OS/new eMMC.
This is still suspicious error for me and i am keep on digging around.
RE: rockpro 64 does not boot up automatically after software reboot - by rahulsharma - 10-24-2019, 01:16 AM
  No audio on HDMI after u-boot upgrade xlx 2 1,986 11-28-2023, 01:03 PM
  Can i use this Emmc for Rockpro 64 Supratec 0 483 09-02-2023, 06:38 AM
Last Post: Supratec
  RP64 Won't Boot After Power Down ColPanic_ 10 7,996 06-27-2023, 07:31 AM
Last Post: dkebler
  NAS setup: weird noise and reboot with 2 3.5" HDs Goffi 4 3,507 02-22-2022, 03:07 PM
Last Post: Goffi
Thumbs Up Generic Watchdog for Reset/Reboot belveder79 1 2,338 12-30-2021, 07:29 AM
Last Post: Huskydog
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 3,583 11-27-2021, 11:38 PM
Last Post: Cerberus
  RockPro64 has bad Memory (Software sogfaults and kernel panics) kop316 20 23,163 08-04-2021, 07:42 PM
Last Post: t4_4t
  zfs on rockpro64 - any dual nvme PCI adapter for software raid ? romadr 0 1,954 04-22-2021, 02:59 PM
Last Post: romadr
  Carte PCIe bloquant le démarrage du Noyau / PCIe card blocking Kernel boot dml-pc 4 5,101 02-17-2021, 11:35 AM
Last Post: dml-pc
  Won't boot with SATA card rjzak 4 5,841 01-09-2021, 05:56 PM
Last Post: kuleszdl
