Pinebook 1080p / KDE Neon freezes every 5-10 min
(09-18-2019, 08:15 AM)rookieone Wrote:
(09-01-2019, 03:11 PM)xircledev Wrote:
(08-20-2019, 11:24 PM)tllim Wrote:
(08-19-2019, 01:34 PM)jezek Wrote: I had freezes every 5-10 minutes.  For mine pinebook, it helped to turn off  sleep, dimm screen and turning screen off after idle. The screen stays always on, but no freezes afterwards. I read somewhere on this forum (or wiki), how to do it, cause in settings it's problematic, but I can't find the article now.  Also I found out, that my pinebook (with KDEneon) can't use video acceleration after wake up from suspend.
There is a lot of update recently. open the terminal and execute below two commands. Hopefully the will be resolved after update.
sudo pkcon refresh
sudo pkcon update
So far, what I've found is that if I use the commands above to update or install packages on my machine instead of using the Discovery application, my machine doesn't freeze up. It's been 12 hours and counting without issue so far.
Was wondering if you are still not experiencing freezes anymore? I've been updating like that for a while but I am guessing I started after one of the updates and perhaps some package is now no longer compatible?
I did the "pkcon" commands as suggested, Since then I have been using the computer in a limited way -- just opening and closing a couple of applications, not doing a lot of resizing and manipulating graphic elements in the GUI (which seemed to lead to freezes before). No freezes. Last night I ran a node.js script that caused the computer to freeze twice in the past -- it ran without a problem. Maybe my problem is solved ... but I'm still testing.
RE: Pinebook 1080p / KDE Neon freezes every 5-10 min - by pyrrhumain - 10-02-2019, 08:37 AM
  DietPi OS for Pinebook MichaIng 3 5,429 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 61,234 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 916 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 704 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,689 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,237 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,889 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,269 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,826 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,809 12-25-2020, 04:40 PM
Last Post: ford442
