Battery and hard drive upgrades et al.
#24
I have to slowly shake my head.
WTF are people expecting? This is first and foremost a Linux machine. You can customize the OS and remove any slack to make it just as big or small as you need it. 64 GB will be great, if you just keep it sensible. Unless, of course, you're going to cut the next blockbuster movie on it. But then you are basically on the wrong boat anyway.
It is, what it is. A cheap appliance that you can toss around as you like without the fear of losing $$$$$. A tool to learn and improve on your Linux - and that includes different desktop environments and slimming down the system. A tool for things to do you don't want to use your valuable MacBook for.
The original PineBook is a tad too far on the lo-spec side now. There are major webpages that don't load on it due to lack of RAM. The PBP will rectify that.
If you want a workhorse, get yourself a Thinkpad x220 from a refurb, put in max RAM and an SSD and buy some spare batteries. You will be able to put any OS - Linux, WIndows or MacOS - on it and work with it productively. And you will possibly pay less than you will pay for a PBP.
PBP is, what the PineBook should have been in the first place. A tinkering machine. A machine to play around without the fear of losing valuable data, A machine to break and fix. The PineBook was broken in too many ways, lack of RAM, flimsy plastic cases ... but it was a start, a concept that points to the right direction.
I have great hopes for the PBP. Still, it won't replace my MacBook or my Surface, but - like it's ancestor - it will follow me to places that I would not dare to take my MacBook to; and this time it hopefully won't disintegrate like the PineBook did....
RE: Battery and hard drive upgrades et al. - by Corkonian - 09-09-2019, 02:51 AM
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 811 09-27-2023, 08:53 PM
Last Post: pinemouth
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 840 07-13-2023, 01:50 PM
Last Post: PaulQ
  Pinebook Pro drains ny battery after shutting it off Tongman 4 2,300 12-01-2022, 02:50 AM
  Battery Frost1776 1 1,105 10-07-2022, 04:17 PM
Last Post: LivingLinux
  Pinebook Pro freezes when running on battery petaramesh 5 2,723 09-22-2022, 12:43 AM
Last Post: petaramesh
Heart Now better battery life or power management? KC9UDX 5 2,405 09-09-2022, 08:13 PM
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,686 02-22-2022, 11:20 AM
  high battery drain on suspend/poweroff wiz 5 5,226 02-10-2022, 11:52 AM
  Customizations or upgrades? ohuw67 4 4,108 08-23-2021, 02:09 PM
Last Post: ohuw67
  NVMe SSD and battery life? dieselnutjob 3 4,048 04-19-2021, 01:55 PM
Last Post: slyecho
