Battery and hard drive upgrades et al.
(08-18-2019, 03:21 PM)neilman Wrote:
(08-18-2019, 03:06 PM)ikhider Wrote: Hello,
A couple of things are important about a laptop to me. First, the battery. Is the battery removable and can I buy a new one? Batteries do wear down so a replacement is important. If the batteries are replaceable, how much would they be?
Next, I missed the free hard drive upgrade and 64 gigs is nothing. How much for the hard drive upgrade?
Finally important, but not always a deal breaker, is screen flex. Some manufacturers add extra plastic around the screen so it is not as flimsy and won't break easily. Is the screen for the laptop stable or does it flex?
Please advise and thanks!
For info the "hard drive" in the PineBook is just a very small (smaller than SD or postage-stamp sized) eMMC memory module.
Current max size is 128GB though (expensive) 256GB is on the horizon.
eMMC is common type of flash-memory format in tablet PCs (and mobile phones?).
There is no provision for a "conventional" (2.5-inch) hard disk or SSD in the PineBook chassis.
Nothing stopping you fitting an external drive to the USB socket though.
@neilman Can you answer any of my questions?
RE: Battery and hard drive upgrades et al. - by ikhider - 08-18-2019, 04:11 PM
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 779 09-27-2023, 08:53 PM
Last Post: pinemouth
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 818 07-13-2023, 01:50 PM
Last Post: PaulQ
  Pinebook Pro drains ny battery after shutting it off Tongman 4 2,212 12-01-2022, 02:50 AM
  Battery Frost1776 1 1,075 10-07-2022, 04:17 PM
Last Post: LivingLinux
  Pinebook Pro freezes when running on battery petaramesh 5 2,644 09-22-2022, 12:43 AM
Last Post: petaramesh
Heart Now better battery life or power management? KC9UDX 5 2,348 09-09-2022, 08:13 PM
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,613 02-22-2022, 11:20 AM
  high battery drain on suspend/poweroff wiz 5 5,146 02-10-2022, 11:52 AM
  Customizations or upgrades? ohuw67 4 4,034 08-23-2021, 02:09 PM
Last Post: ohuw67
  NVMe SSD and battery life? dieselnutjob 3 3,998 04-19-2021, 01:55 PM
Last Post: slyecho
